Rough Finish on 45 Degree wall - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 63 of 63
Thread: Rough Finish on 45 Degree wall
  1. #61
    Member Need TECH Help!'s Avatar
    Dec 2007
    Default Re: Rough Finish on 45 Degree wall
    matec45,
    Part looks nice, but cant really tell the finish of angled walls at that distance, but the issue iam having is most noticeable at 45*.
    What size DMMs are you using? What Mode is your drive? And are you using Dynomotion boards?
    www.tsjobshop.com, www.homecncstuff.elementfx.com
  2. #62
    Jan 2005
    Quote Originally Posted by Need TECH Help! View Post
    matec45,
    750w motors +/- 10 volt analog control, using Dynomotion No, SoftServo control
    I use there Servo's on more than one machine some are step/dir for simplicity with different controls they all work very well
    Mactec54
  3. #63
    May 2012
    canada
    Few more pictures of some 1" thick stainless parts I made this week. The center square happened to be orientated at 45 degrees in the drawing so I ran it like that to see what finish would be like. This was with brand new endmill and in stainless so fairly low rpm and therefore lower vibration. I think it was 2500 rpm and 20 ipm. Pretty good results at this speed. If you look really close you can still see slight variation in the interpolation vs straight cuts, but im happy with this as it is.
    Are you still using torque mode? Hows it working?
    Attached Thumbnails Attached Thumbnails Rough Finish on 45 Degree wall-20200520_211339-jpg   Rough Finish on 45 Degree wall-20200520_192944-jpg   Rough Finish on 45 Degree wall-20200520_192952-jpg
