Need Help! Warner/Swasey QCM-6 lathe with Kflop/Kanalog - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 101 to 115 of 115
Thread: Warner/Swasey QCM-6 lathe with Kflop/Kanalog
  1. #101
    Jun 2006
    Default Re: Warner/Swasey QCM-6 lathe with Kflop/Kanalog
    Hi Tom,
    I don't understand why I can't get higher a 'P' value. no matter what i try, it seems that in order to have stability with larger moves, P is going to be around .12 and D is going to be around 90. And I still don't have a good plot. I can move P and D up proportionally above P=1.0, but lose stability on larger moves.
    This drive has a feature called Torque Hold, which is activated by jumping terminals 6 & 7 on the drive terminal strip. My understanding is that it overrides the tach signal and puts the drive in torque mode. There is also a feature called External Current Limit. My understanding is that it limits drive current for testing purposes. It is activated by jumping from the drive terminal strip common to terminal 9. Per advise from Mike, the drive specialist, External Current Limit has been active since I had the first problems with the drives. He advised to leave it on until ready to cut chips as a precaution. I ran some tests, all with the same parameters, with various combinations of tach on/off, torque hold on/off, external current limit on/off, and tach terminals jumpered. As expected, it doesn't seem to matter much if the tach is on or off, if the torque hold is on. see notes in plot window for what is on/off.
    Plot and Data 28
    Warner/Swasey QCM-6 lathe with Kflop/Kanalog-stepresponse28-png
    Data28.zip
    Plot and Data 29
    Warner/Swasey QCM-6 lathe with Kflop/Kanalog-stepresponse29-png
    Data29.zip
    Data 30, Plot in next post, Exceeded file # limit
    Data30.zip
    Data 31, Plot in next post, Exceeded file # limit
    Data31.zip
    Attached Files Attached Files
  2. #102
    Jun 2006
    I hope my attempt to post too many files doesn't make a mess. Note that Plot and Data files share a common number (28-33).
    Plot and Data 30
    Warner/Swasey QCM-6 lathe with Kflop/Kanalog-stepresponse30-png
    Data30.zip
    Plot and Data 31
    Warner/Swasey QCM-6 lathe with Kflop/Kanalog-stepresponse31-png
    Data31.zip
    Plot and Data 32
    Warner/Swasey QCM-6 lathe with Kflop/Kanalog-stepresponse32-png
    Data32.zip
    Plot and Data 33
    Warner/Swasey QCM-6 lathe with Kflop/Kanalog-stepresponse33-png
    Data33.zip
  3. #103
    Jun 2006
    Hi Tom,
    I pulled the tach cable out of the factory routing and looped it over and away from other wiring. Ran a plot with same parameters as above.
    Plot and Data 34
    Warner/Swasey QCM-6 lathe with Kflop/Kanalog-stepresponse34-png
    Data34.zip
  4. #104
    Member TomKerekes's Avatar
    May 2006
    Hi Charles,
    Looking at the schematics I think shorting Torque hold may reduce the input gain and also effectively defeat some Lag compensation. This seems to be corroborated in the plots with smoother motion and larger errors as one would expect by turning down the P D Gains. I'd recommend trying shorting the Torque Hold (not sure why they call it Hold?). But then optimizing the tuning (increasing gains).
    I'm assuming these are all small size moves that don't ever have any problem with higher gains. I would have tested large moves and tune higher gains to see which performs better.
    You might check if the current limit Output ever pulses while making bigger moves.
    The Amplifier has some non-linear "Gain changing" components which reduce the gain at higher currents? Its not clear how to defeat that or if it is in use.
    I see there is a current monitor out. I suppose we could connect that to a Kanalog ADC. A program could be written to capture data and analyze what the Amplifier is doing. Maybe ramp the DAC up and down and monitor the actual current to see how linear and with what lag.
    Thes amplifiers are from 1973? I found a related patent listed in the manual I found. Do you have any idea how well the original control ever worked? Modern drives switch using FETs at like 20KHz vs these with SCRs switching at 120Hz. So it isn't clear how well it could ever work. You might consider trying a modern Drive such as an AMC to see if the performance is greatly improved. They can often be found 2nd hand fairly inexpensively.
    Regards
    TK http://dynomotion.com
  5. #105
    Jun 2006
    Hi Tom,
    I will test as you suggested. I did run this machine years ago when I first got it. It had a very early GE2000 control with a few short programs in memory. I think they were demo or test programs. As I said before, this machine came from a community college. I don't think it ever ran very much at all. Probably sat powered up most of its 400 hours. The programs were contouring and threading on 1" round stock. I'm pretty sure it was running CSS when it cut the ball end on the part. It ran fine, good surface finish, good threads.
    I didn't have the source code for the control, so I couldn't upgrade the software. After I let it set for several years, the control would not power up. That's when I started looking at Kflop/Kanalog.
    I was hoping to use the original drives in order to keep the cost down. I'm not opposed to considering other options, if it can be done at a reasonable cost. I don't know how to select a replacement drive. According to the existing drive manual, the axis drive is 40 amp, controlled by a +/- 10V analog signal. Motors are DC brush with tachs and encoders. I don't know the torque rating of the motors.
    The spindle motor is 7.5 hp and the spindle drive is similar to the axis drive but 85 amps. I hope it is usable. I need to test it before I get too deep into all this. I assume it is to be tuned about the same as the axis drive.
    As has been mentioned several times, this machine is in such excellent condition mechanically that it would be a shame to not get some use out of it.
    Please excuse the rant. I'm just getting frustrated with my lack of progress, mainly due to not knowing what I'm doing.
    Thanks,
    CJS
  6. #106
    May 2006
    I just mentioned this if you are in a rush to find a solution it would probably be worth while. Used AMC Drives can often be found on Ebay for less than $100. You can go with less voltage and less current from the original drives (especially for a test). But the max speed and max acceleration will be limited respectively. I doubt if this would be an issue for the small/slow test moves that we've been looking at. One thing that just occurred to me is that this system doesn't have a DC Motor Supply as it works by applying portions of the AC cycles. Most AMC drives will require a DC Supply.
    Yes I would test this ASAP. But Spindles are not usually very demanding as compared to Axes Drives. Gradual speed changes are normally sufficient.
    Hang in there
    Regards
  7. #107
    Jun 2006
    Hi Tom, and anyone who has ideas on affordable newer drives. I've been looking at AMC drives on ebay. Plenty of what appears to be 12 amp drives. Mostly for brushless or PWM motors. With my existing drives, just how low do you think I could go on drive amperage and get reasonable performance? I saw somewhere that brushless drives could be used by connecting only 2 motor wires. Do you or anyone know about this? I guess I could try a 12 amp drive just to test everything else. The spindle seems to work pretty well with DAC commands. Will post results of spindle runs. Do I need to the spindle as an axis for closed loop results?
    Thanks,
    CJS
  8. #108
    May 2006
    Hi CJS,
    80V @ 12A is 960Watts of Power which is more than 1HP. I would suspect it would be fine for tests.
    Attached is an App Note from AMC. Basically set 60 degree phasing, no Hall sensor connections and connect motor between Motor 1 and Motor 22.
    Regards
  9. #109
    Jun 2006
    Hi Tom,
    I think I will find a 12-? Amp AMC drive for at least testing. Looks like I can try it in velocity mode with the tach or torque mode without the tach by setting a switch. I will also have to work out a dc power supply.
    My spindle motor drives the spindle through a toothed belt with the motor turning 1 turn for 2 turns of the spindle and the belt driven encoder. Looks backwards to me, but I guess it's overdriving for a reason. Using DAC commands, I get the following:
    DAC2, rpm spindle, rpm motor
    100,. 235, 118
    200, 467,. 234
    300,. 702,. 351
    400,. 936,. 468
    500,. 1172, 587
    600,. 1408,. 704
    700, 1644,. 822
    725,. 1701,. 851
    750,. 1741,. 871
    775,. 1742,. 872
    800,. 1742,. 872
    I expected higher spindle speeds. But I do still have current limit active on the spindle drive.
    Negative DAC commands produce the same rpms in opposite rotation.
    Thanks,
    CJS
  10. #110
    May 2006
    Hi CJS,
    Motor RPM max of 872 RPM seems low. I wouldn't expect a current limit to limit unloaded speed. BTW are you applying 240V 3 phase line power? What kind of isolation transformer does this have?
    It seems the TPA/2-15640 means the internal AC voltage should be 156V AC RMS? Have you ever check that?
    Regards
  11. #111
    Jun 2006
    Hi Tom,
    This machine originally of course was 460 volt three phase. I'm using a 10 hp phase converter to produce about 230 volts three phase with a wild leg. With the machine powered up, hydraulics running, input to the transformer are 123, 168, 123, VAC line to neutral and 219, 213, 248, VAC line to line. Transformer output to drives are labeled to be 275 VAC L-L. They are 278, 231, 281 VAC. Line to neutral are 141, 169, 142. Looking at the drive tag again, I now think it is 15840 instead of 15640, as the manual lists 120, 138, or 158 as "Secondary Line to Neutral Voltage" options. The spindle is 15885. The 40 and 85 are "Continuous Current Rating." I can post the transformer details later. I did switch the transformer jumpers from 460 to 230 per the tag on the transformer. There is a separate transformer for the 120 VAC and 39 VAC, which feeds the 24 VDC power supply.
    I suspected the phase converter imbalance may be a problem, but I was told by someone who should know that it was not a problem. The drive chops it up and converts it to DC anyway.
    One wrinkle that just occurred to me, the machine is labeled as 40 amps at 460 volts. Changing it to 230 volts means it now requires 80 amps. I'm not sure it's getting enough current.
  12. #112
    May 2006
    Hi CJS,
    230V @ 40A is over 10HP. Unless more power than this is needed it shouldn't be a problem. I don't think the small relatively slow moves we are testing should take much power.
    Regards
  13. #113
    Jun 2006
    Hi Tom,
    The transformer is labeled as follows:
    KVA 24:3
    Primary 230/460 Delta
    Amp 54.9/27.5
    Secondary 275Y/159
    Amp 56.12 AC
    This transformer only serves the spindle and axis drives.
    There is a second transformer for 120 VAC and 39 VAC which feeds the 24 VDC power supply. Also a hydraulic pump motor and coolant pump motor.
    Found an AMC 25 amp peak PWM brushless drive with built-in power supply, 120VAC input. Most of what I see require a separate power supply.
    Thanks,
    CJS
  14. #114
    Jun 2006
    Hi Tom,
    I am looking at an AMC 30A8 drive that is rated at 30 amps peak, 15 continuous, and 80 volts. The price is very affordable, but I'm guessing it will operate the motor at only about half the motor's capacity, which is fine for testing, and may be ok on this machine.
    Am I correct in assuming the power supply should be rated at the same amperage and voltage as the drive output? Also, does the power supply need a transformer for isolation, or can the 120vac line current be rectified directly to ~84vdc?
    Thanks,
    CJS
  15. #115
    May 2006
    Hi CJS,
    I agree. Voltage limits motor RPM. So expect about half maximum velocity (assuming the original supplied 160V?)
    That would be best but not absolutely necessary. Higher would be ok but not useful. Lower will simply limit the speed and accelerations that you will be able to do.
    Yes
    No. Rectified 120VAC RMS would be ~ 170VDC. If the amplifier is limited to 80VDC never apply more than 80VDC. Note some non-regulated linear supply's voltage increase when unloaded so you should be careful with this. AnTek is a commonly used supplier for linear supplies.
    Regards
