Parallel lines
Results 1 to 7 of 7
Thread: Parallel lines
    Oct 2014
    Default Parallel lines
    Please could you help me. I’ve to put in parallel two line of engines. Examplíe: x with z and y with a. Which is the command that I’ve to applaid?
    Thanks a lot. Dalmazio.
    Member TomKerekes's Avatar
    May 2006
    Default Re: Parallel lines
    Hi Dalmazio,
    I don't understand what you are asking. Possibly Master/Slave configuration?
    Regards
    TK http://dynomotion.com
    Oct 2014
    [QUOTE = TomKerekes; 2341958] Ciao Dalmazio,
    non capisco cosa stai chiedendo. Possibile configurazione Master / Slave ? [/ QUOTE]
    dear tom, yes, x master z slave, y master a slave thank
    Oct 2014
    May 2006
    Hi Dalmazio,
    I'm not sure whether you still have a question.
    It would be better to reference KFLOP Axis Channels. ie.
    X = Master KFLOP Axis #0, Slave KFLOP Axis #2
    Y = Master KFLOP Axis #1, Slave KFLOP Axis #3
    Regards
    Oct 2014
    thanks tom, should I write these commands in the consol?
  7. #7
    May 2006
    Hi Dalmazio,
    No you should configure the KFLOP Axes appropriately in the configuration screen as described in the Link I provided. Configure the each Slave axes to follow the appropriate Master.
    Then configure the XY Coordinate System with:
    DefineCoordSystem(0,1,-1,-1); // define X as Axis #0 and Y as Axis #1
    Regards
Parallel lines
Parallel lines
Parallel lines
