Need Help! KFLOP & Mach3: Configure STEP PER - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: KFLOP & Mach3: Configure STEP PER
  1. #13
    Member TomKerekes's Avatar
    May 2006
    Default Re: KFLOP & Mach3: Configure STEP PER
    This line:
    FPGA(STEP_PULSE_LENGTH_ADD) = 32 + 0x80;
    is setting the step pulse width to 32 / 16.67 MHz = 1.92us
    At high speed (step rates) shorter pulses are needed in order to have some time between pulses. It seems you are using 150000 steps/sec which is a period 6.7us so the pulse width should probably be kept shorter than about half of that.
    Regards
    TK http://dynomotion.com
  2. #14
    Oct 2017
    Italy
    Yes Tom, I forgot to write this change in the post.
    With FPGA(STEP_PULSE_LENGTH_ADD) = 32 + 0x80; the motors travel work, but sound a little strange.
    With FPGA(STEP_PULSE_LENGTH_ADD) = 63 + 0x80; all oK
