Stopping oiler when machine is idle
Results 1 to 4 of 4
Thread: Stopping oiler when machine is idle
    May 2012
    canada
    Default Stopping oiler when machine is idle
    Hi Tom,
    Is there any easy way to detect when the machine is idle for a period of time? Would be nice if I could disable the oiler after say 10 mins of no movement. Thanks.
    Mark
    Member Sterob's Avatar
    Jan 2007
    Default Re: Stopping oiler when machine is idle
    Control the Oiler via a relay contact on your VFD, so it comes on when the VFD starts the motor, and fit an electronic timer configured to give a 10min delay off when the contact opens on the VFD.
    Member TomKerekes's Avatar
    May 2006
    Hi Mark,
    You might do something similar to how KStep is disabled after a period of no motion. Enable the Oiler and TimeStamp the time whenever there is motion, and if the current time is a certain amount past the TimeStamp then disable the oiler.
    Code:
    	for (;;) // loop forever
    		WaitNextTimeSlice();
    		// Service Amplifier disable after no activity for a while
    		if (ch0->Dest != LastX || ch1->Dest != LastY || ch2->Dest != LastZ)
    			// we moved - enable KStep Amplifers
    			SetBit(45);
    			T0 = Time_sec();  // record the time and position of last motion
    			LastX=ch0->Dest;
    			LastY=ch1->Dest;
    			LastZ=ch2->Dest;
    		else
    			if (Time_sec() > T0 + 10.0) ClearBit(45);
    Regards
    TK http://dynomotion.com
    May 2012
    canada
    Quote Originally Posted by TomKerekes View Post
    Hi Mark,
    Code:
    			SetBit(45);
    			LastX=ch0->Dest;
    			LastY=ch1->Dest;
    			LastZ=ch2->Dest;
    		else
    Thanks Tom, Worked perfectly.
