Need Help! Setting Zero and divide by 2
Results 1 to 7 of 7
Thread: Setting Zero and divide by 2
    Dec 2012
    Norway
    Default Setting Zero and divide by 2
    Hi, Tom.
    When setting the 0-point, is there a way to divide by 2 when edgefinding both opposite sides of the stock to set 0 in the center? In both Mach3 and PathPilot you can set 0 in one edge and click the DRO on the edge of the other side press "/2" and Enter to divide the current DRO value in two. I tried this with KmotionCNC, but I got an error message. I checked the manual and the wiki, without finding anything.
    Member TomKerekes's Avatar
    May 2006
    Default Re: Setting Zero and divide by 2
    Hi Stigoe,
    You could configure a User Button to do this. See the CenterFindByHalfKMotionCNCDROX.c example.
    Code:
    #include "KMotionDef.h"
    #define TMP 10 // which spare persist to use to transfer data
    #include "KflopToKMotionCNCFunctions.c"
    main()
        double DROx, DROy, DROz, DROa, DROb, DROc;
        GetDROs(&DROx, &DROy, &DROz, &DROa, &DROb, &DROc);
        DoPCFloat(PC_COMM_SET_X, DROx/2);
    But that sounds like a good feature to add to the Set DRO dialogs. What Version of KMotionCNC are you using? If you want we can post a patch to add this.
    Regards
    TK http://dynomotion.com
    May 2012
    canada
    Quote Originally Posted by TomKerekes View Post
    That sounds like a great idea Tom. I always have to break out the calculator and this would be much easier!
    Dec 2012
    Norway
    Hi Stigoe,
    Hi, Tom.
    I'm using the latest version (4.34).
    Br,
    Stig
    May 2006
    Hi Stig,
    Here is a patch for V4.34. Copy to <>\KMotion\Release\ folder.
    The Set Dialog should then look like this:
    Setting Zero and divide by 2-usedro2-png
    Please let us know if it works for you. Changed sources are also on the server if needed.
    Regards
    Dec 2012
    Norway
    Hi Stig,
    Hi, Tom.
    Thanks! Unfortunately, I've just left for work and will be gone for 5 weeks, so I won't have the chance to test until I'm back. Unless someone else tests in the meantime, I'll let you know when I'm back.
    Stig
  7. #7
    May 2012
    canada
    I tried it last night Tom, seems to work fine. This will be very useful, thanks for adding this feature.
