Need Help! Transfer settins
Results 1 to 2 of 2
Thread: Transfer settins
    Jun 2019
    Default Transfer settins
    Hi. Is there a special function to transfer all settings from one computer to another? Something like "export all settins" button?
    C programs copy/past not big problem. But, for example, Kmotion.cnc settings like "trajectory planner", it should move from the first pc to the second simply by rewriting the field behind the field?
    Member TomKerekes's Avatar
    May 2006
    Default Re: Transfer settins
    Hi Evg_4,
    The KMotionCNC Tool Setup parameters are saved in the file <>\KMotion\Data\GCodeConfigCNC.txt
    If any other files were changed it is simplest to copy the entire <>\KMotion\Data directory to the other computer.
    Regards
    TK http://dynomotion.com
Transfer settins
Transfer settins
