Hi RuslanRobot,
See the "Stop when low" option in the Limit Switch Options.1. I can't find where in the system KFLOP I can invert the input signal from end sensors. I have several end sensors of the Normally Open type, and the signal from them need to be inverted. Also I have end sensors of Normally Closed type, and they work as we need, without problems. How to invert the input signal from end sensors?
There isn't any fixed EStop functionality. You need to decide what you want the EStop button to do. You might look at the EStopDisablesAll.c example.2. I connected the EStop button. Program KMotion indicated the activation of the button (I/O satus and the light on the Konnect, - when I push it). How to specify in the settings the appointment of the signal - as the emergency stop button?
HTH
