Hi RuslanRobot,
I don't understand. If you toggle Virtual Bit 60 on the KMotion | Digital IO | Virtual Screen does the Pneumo-relay toggle on and off?Pneumo-relay connected to Konnect pins Out 12, 13, 14, 15.
In the Kmotion -> Digital I/O -> Virtual, I see flags opposit connected pins.
If so, this is how you might configure your MCodes:need commands in G code to turn on and off relay:
M100 turn on relay pin12.
M101 turn off relay pin12.
M102 turn on relay pin13.
M103 turn off relay pin13 (and so on, to pin15).
Please remember to put reverse flyback diodes across any solenoid or relay coils.
