New Machine Build Wells-Index Mill 320 retrofit
Results 1 to 2 of 2
Thread: Wells-Index Mill 320 retrofit
    Member oxford's Avatar
    Mar 2008
    Default Wells-Index Mill 320 retrofit
    Howdy,
    Took me a while to get to a point in my life where I could dabble in CNC milling again. Finally have the space to work on a respectably sized mill. A friend of mine at work decided to unload his Wells Index Mill 320 at price I couldn't refuse. Anyway, one good deed deserves another. In my tare-down phase right now. The encoders and some of the other electronics look good. Been pulling them apart carefully, in case there is someone out there that is into taking these old control systems and restoring them. Pictures posted for anyone interested. For those that are super interested in saving the old controller, I am in Austin Texas. PM me if you want to pick the electronics up.
    Plan is to retrofit with Kanalog, Yaskawa AC drives and controllers, and install new encoders to work with the new Dynomotion controller.
    I need to get myself a precision surface to work on the ways. Any suggestions for the Austin, Texas area? Largest dimension is 42"
    Thanks all!
    Attached Thumbnails Attached Thumbnails Wells-Index Mill 320 retrofit-img_20190601_141412757-jpg   Wells-Index Mill 320 retrofit-img_20190601_141427964-jpg   Wells-Index Mill 320 retrofit-img_20190601_145915967-jpg   Wells-Index Mill 320 retrofit-img_20190601_150404102-jpg
    Mar 2008
    Default Re: Wells-Index Mill 320 retrofit
    Slow and steady wins the race...I hope.
    Still in the teardown phase.
    In the process of trying to pull the table apart. I have no idea how to remove this knob from the ball screw. Pictures below.
    Any ideas?
    Attached Thumbnails Attached Thumbnails Wells-Index Mill 320 retrofit-axis2-jpg   Wells-Index Mill 320 retrofit-axis1-jpg
