Hi RuslanRobot,
You need to put these two lines of code:
InitAux();
AddKonnect(0,&VirtualBits,VirtualBitsEx);
inside the main() function so they get executed.
You might read this.
HTH
Please, we need help!!!
What was done (see attached files):
Konnect was connected to the Kflop through jp6 whith a ribbon cable that was lying in the kit;
in a C-file a Konnect board was initialized by a two strins from a manual:
InitAux();
hit the "init" button;
Four step-motors work propperly.
But when the input is activated by applying voltage to Konnect board, no reaction takes place in the Kmotionion console,
as well as in the Digital I/O window. But the green LED in front of the input on the Kmotion board lights up.
On a Konnect board pin 24 activated. Sending in console "readbit1048" always return "0". In both cases - LED on, or LED off (when we disconnected power).
So, we can't setup pneumo relay and home limits. And we don't understand, - what we did wrong?
Hi RuslanRobot,
InitAux();
HTH
Regards
TK http://dynomotion.com
Yes it 's work!!! Thank you.
