Is my KFLOP a supported version?
Results 1 to 6 of 6
Thread: Is my KFLOP a supported version?
    Feb 2010
    Denmark
    Default Is my KFLOP a supported version?
    I bought a KFLOP some years back, but never got around to use it.
    I now have a project where I want to use the board, but I am unsure if the version of KFLOP I have is still a current version.
    On the PCB it says KFLOP rev 1.2. Is this still a supported version of KFLOP?
    Best regards
    Jacob
    Member TomKerekes's Avatar
    May 2006
    Default Re: Is my KFLOP a supported version?
    Hi Jacob,
    The only difference between KFLOP Rev 1.2 and the current KFLOP Rev 1.3 is additional noise filtering on the KFLOP Reset input. With long cables and signal cross talk or in a noisy evironment could sometimes cause KFLOP to reset. Otherwise they are identical.
    Here is a post showing a method of adding a 0.001uF Ceramic Capacitor near KFLOP to make is the same as a Rev 1.3 board.
    https://www.cnczone.com/forums/dynom...ml#post1661110
    HTH
    Regards
    TK http://dynomotion.com
    Feb 2010
    Denmark
    Quote Originally Posted by TomKerekes View Post
    Hi Jacob,
    HTH
    Hi Tom,
    Thanks for the answer. I will add the capacitor and run with my current board.
    Best regards
    Jacob
    Jan 2006
    I have the same question as well, except mine is KFLOP REV 1.1
    I really need to retire so I'll have some time to use all this cool stuff!
    May 2006
    Hi frostheave,
    Yes it should be software compatible.
    Regards
    Jan 2006
    Excellent. Thank-you Tom.
    I will also add the cap.
    I'm looking forward to finally using the KFLOP.
    Bob
