Problem Read ADC from KNOZZ
Results 1 to 3 of 3
Thread: Read ADC from KNOZZ
    Registered cowleym's Avatar
    Oct 2007
    UK
    Default Read ADC from KNOZZ
    Hi
    I am a new to the Dynomotion kit and so far am very pleased. Using LabVIEW and.net I have created a trajectory planner, coordinated motion from dxf files, along with buffer control and process flags.
    So far so good.
    I now want to look at implementing plasma arc voltage control and have purchased a Knozz board for the analog input functions.
    I would like to put these values in the persist array so I can read them using GetPersist and do stuff with Labview.
    I have looked at the KnozzControlTemps programme and can see that it almost does what I want, but am struggling with defining the analog values and writing to the persist array.
    Could you give me some guidance please as I have no knowledge of C .
    Many thanks
    Mike
    Registered TomKerekes's Avatar
    May 2006
    Default Re: Read ADC from KNOZZ
    Hi Mike,
    After reading the bed ADC reading via SPI into raw_counts_bed you could then place the integer ADC reading into persist variable 150 with:
    persist.UserData[150] = raw_counts_bed;
    HTH
    Regards
    TK http://dynomotion.com
    Oct 2007
    UK
    Hi
    that works very well thank you.
    Thanks again for the quick response.
    Mike
Read ADC from KNOZZ
Read ADC from KNOZZ
