Y axis limit switch not detecting or it detects at zero
Results 1 to 2 of 2
Thread: Y axis limit switch not detecting or it detects at zero
    Gold Member amitkumar171's Avatar
    Aug 2017
    India
    Default Y axis limit switch not detecting or it detects at zero
    Hi all ,
    I am using Kflop Board , in that board i am connecting pin IO 0 AND IO 6 to my limit switch for y axis. IO0 for positive and IO1 for negative.
    When i am trying to move y axis from 0 to positive it detects the limit switch and stops the axis.
    similarly from 0 to negative direction it is detecting and stopping the axis. That it is supposed to do.
    But when i am trying to move from +10 to 0 it only detects when it reached 0 whether it detects limit or not it reaches to 0 and stops.
    Similarly if am moving y axis from -10 to 0 it only detects when it reaches 0 before that whether it detects limit or not it reaches to 0 and stops and detects limit at 0.
    It only happening in y axis as axis channel generator 1, all other axis and their limits are working fine.
    Please solve my issue.
    Waiting for your kind reply
    Regards
    Amit Kumar
    Member TomKerekes's Avatar
    May 2006
    Default Re: Y axis limit switch not detecting or it detects at zero
    Hi Amit,
    Check if your Soft Limits are set correctly. Post your Initialization file.
    Regards
    TK http://dynomotion.com
