Grounding
Results 1 to 2 of 2
Thread: Grounding
    May 2014
    Default Grounding
    I never bothered running a ground wire from the 220V plug, to the J1 connector on KSTEP, so it always just ran of the +/- from the transformer/capacitors, with the ground on the 220V plug cut off. Should i bother running the ground wire to the J1 from the 220V plug?
    Dec 2003
    Default Re: Grounding
    A system that is mains powered should always be earth grounded for safety.
    You should also use it for any motor frame grounding and enclosures etc.
    See NFPA79 for a reference.
Grounding
Grounding
