Hi Mike,
Its saying Labview can't find our libraries. The simplest thing is probably to add our:
<Install Directory>\KMotion\Release
to your Windows Path.
Hi
I have just started messing with the Dynomition Kflop board.
I hope to use the controller with my existing LabVIEW front end but I am having some difficulty getting started.
I have installed the software package to my pc and run the KmotionCNC.
All is good, the software sees the board and I can run the Gcode programmes.
I then tried to run the Labview sample programme Kmotion Dot Net Sample.vi and get the following error
Constructor Node Error creating instance of KM_Controller in assembly KMotion_dotNet.KM_Controller, KMotion_dotNet, Version=1.0.1.0, Culture=neutral, PublicKeyToken=fcaf9556d6f68c3a, (KMotion_dotNet.DMException: Dll Not Found Exception thrown : Caller - [KMotion_dotNet.KM_Controller] :: Member - [KM_Controller]) <append><b>KMotion_dotNet.DMException</b> in Kmotion DotNet DLL Sample.vi
I don't really understand what this means, could you offer any guidance please.
I am running Windows 10 and Labview 2018 32 bit
Many thanks
Mike
Techserv.blog
Hi Mike,
Regards
TK http://dynomotion.com
brilliant that fixed it.
Many thanks for your rapid response.
Cheers
Mike
