Hi Joe,
Strange. The directory path should be unspecified and therefore default to the Install Directory normally C:\KMotion434\C Programs
The new program needs to be configured properly for your system. Normally this is accomplished by copying the file
\KMotion\Data\GCodeConfigCNC.txt
From the previous version as described here.
Otherwise you can always set the Tool Setup properly for your system manually.
Apparently you don't require any safe Z move on Halt, or any M6 operations, so you can change those actions to "None".
