Need Help! G43 G49 status Led and Toggle
Results 1 to 8 of 8
Thread: G43 G49 status Led and Toggle
    Mar 2013
    us
    Default G43 G49 status Led and Toggle
    Hello everyone I am trying to implement a button to turn tool length compensation on and off or at the least a Led to see the status.
    Only thing I can think of is to monitor the variables for tool length offset and current fixture offset
    Is there an easier solution
    I don't have the ability to recompile from visual studio.
    Member TomKerekes's Avatar
    May 2006
    Default Re: G43 G49 status Led and Toggle
    Hi dirtdigger257,
    I can't think of an easy way to do this without adding some new functionality.
    The Tool Length Index is -1 when Length Compensation is turned off.
    Here is a C Program that maintains a Virtual Bit (actually a KFLOP LED Bit 46) based on periodically requesting the Index
    Code:
    #include "KMotionDef.h"
    #define TMP 10                    // which spare persist to use to transfer data
    #include "KflopToKMotionCNCFunctions.c"
    void ServiceToolOffsetMode(void);
    main()
        for (;;)                    // forever loop
            ServiceToolOffsetMode();
    #define STATUSBIT 46
    // periodically set Virtual Bit based on Tool Table Index
        static double LastTime = 0;
        int Units, TWORD, HWORD, DWORD;
        if (Time_sec() < LastTime + 0.3)
            return;
        LastTime = Time_sec();
        GetMiscSettings(&Units, &TWORD, &HWORD, &DWORD);
        SetStateBit(STATUSBIT, HWORD != -1);
    Attached Program and Screen Script
    Attached Files Attached Files
    Regards
    TK http://dynomotion.com
    Mar 2013
    us
    Thanks works great
    Is it ok to have two for loops running in separate threads
    one in my init the for the MPG
    the other for servicing KmotioCNC jog rate and tool offset?
    If not it take to long to run threw the init for loop and cause problems jogging.
    May 2006
    Hi dirtdigger257,
    You could use 2 Threads but each extra Thread increases the time between Time Slices so it is better to use less Threads where possible.
    Please try the code below (and attached) that is written in a non-blocking manner so your MPG should always be serviced using a single loop.
    Code:
    main()
    // keeps track of state of sequence to always return immediately
        static BOOL WaitingForResponse = FALSE;
        int HWORD;
        if (WaitingForResponse)        // Waiting for a response from the PC?
            if (persist.UserData[PC_COMM_PERSIST] <= 0)    // Has PC Responded??
                HWORD = persist.UserData[TMP + 2];    // Get Tool H Word
                SetStateBit(STATUSBIT, HWORD != -1);    // -1 indicates no active offset
        else
            if (Time_sec() > LastTime + 0.3)    // only request periodically
                DoPCIntNoWait(PC_COMM_GET_MISC_SETTINGS, TMP);    // Request settings from PC
                WaitingForResponse = TRUE;    // Remember we are waiting for a response
    Regards
    Member amitkumar171's Avatar
    Aug 2017
    India
    Quote Originally Posted by TomKerekes View Post
    Hi dirtdigger257,
    Code:
    main()
        int HWORD;
        else
    Hi tom,
    Thanks for your reply, i am having some problem while running the above c program,
    The issue is When i am starting KmotionCNC.exe first time then it runs fine.
    But when i am giving G49 and closing KmotionCNC.exe
    After running the KmotionCNC.exe again i am getting LED On state but , i turned it off while closing KmotionCNC.exe
    I want this whole state off or on untill unless i give G43 H1001 or G43.4 H1001 or G49.
    Closing KmotionCNC should not reset it.
    Regards
    Amit Kumar
    May 2006
    Hi Amit,
    The LED is displaying the true state of the Interpreter.
    If the Tool Setup Options: Tool Length/Offset Immediately and M6 on Tool Table Changes
    G43 G49 status Led and Toggle-toollengthimmediately-png
    are selected, then when KMotionCNC starts up the Tool Compensation is enabled and set to match the selected tool displayed on the screen:
    G43 G49 status Led and Toggle-selectedtool-png
    If those options are not selected then the Settings File parameter slot_for_length_offset
    G43 G49 status Led and Toggle-setupfile-png
    can be used to initialize which Tool is in use or -1 for not applied.
    If no setting is included the Interpreter length offset is initialized to -1 for none.
    Disable the Options and set the Settings file parameter slot_for_length_offset to -1 to initialize the Interpreter with no Length Compensation in effect.
    Regards
  7. #7
    Aug 2017
    India
    Hi Amit,
    Hi tom,
    I tried the above method for the tool offset led toggle, i am facing one problem that,
    When i am turning power on the kflop board its remembering its last state wheather it was turned on or off last time.
    But i don't want to remember that, i just want after every power recycle G43 G49, LED should be initially off.and i have to manually turn it ON on every power off and on Sequence.
    Waiting for your kind reply.
    Regards
    Amit Kumar
  8. #8
    May 2006
    Hi Amit,
    Please be more specific what you are doing.
    Regards
