G code viewer questions...
Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: G code viewer questions...
    May 2012
    canada
    Default G code viewer questions...
    Hi Tom,
    I have a few questions about the g code viewer. Honestly I haven't used the g code viewer much but after playing with the transfrom low pass filter ive been finding it handy.
    1. On my mill I cant seem to get any toolpaths to display at all? I can only use the g-code viewer on my office computer. If i click settings they appear to be the same, but nothing shows up on my mill? Any ideas? Do i have some settings wrong or could a custom screen be causing it?
    2. Is this showing the G-code or the path after its ran through the trajectory planner? If i change TP settings I see the same result, but in your video here it shows the results of the changes. Are you doing something different here? How are you viewing the changes in the trajectory planner?
    3. Is there any other way to zoom other then mouse wheel? If not could the increments be smaller? I find things tend to be too small and then one more increment and its off the screen.
    Thanks.
    Mark
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: G code viewer questions...
    Hi Mark,
    If you are using the Screen Editor then the path is directed to the GViewer on the Main Screen rather than the separate resizable screen. You will need to switch to a Standard Screen Face or enable the GViewer Control on one of your Screens.
    Yes
    You must actually run a Job to see the Trajectory Planned Result.
    Yes. See the help:
    G Code Viewer Screen
    Click and drag the right mouse Button to translate closer or farther.
    After 3 seconds of moving the resolution increases.
    May 2012
    canada
    Quote Originally Posted by TomKerekes View Post
    Hi Mark,
    Yes
    Yes. See the help:
    Ok, how do I enable the GViewer Control from a custom screen? I have the button there to open the G viewer, and it opens and looks fine, just doesnt show the toolpaths. It is a screen issue for sure, tried a custom screen on my office computer and it stopped working. I attached my custom screen if you want to take a look.
    Right mouse button is working for zoom, thanks I missed that somehow.
    Attached Files Attached Files
    May 2006
    Hi Mark,
    By popular demand when using a Custom Screen the GCode Viewer is now part of the main dialog screen and all path info is directed to and displayed there instead of the separate GViewer Screen.
    If you "Show" the GCode Viewer Control on your Screen it should show the tool paths. You might hide the button that brings up the separate GViewer Screen.
    See this video.
    May 2012
    canada
    Ok i was wondering how you got it to change from code to viewer to split, but I see now how you did it with 3 seperate screens. Cool.
    So if I want i can just make 2 or 3 versions of my screen and configure an unused label button to switch between them? So all i need to do is put "SScript:ScreenName.scr" under script to get the button to switch screens?
    May 2006
    Hi Mark,
    Yes. You can also use the '>' browse button to configure the action and browse for the screen script file to format that syntax for you.
  7. #7
    May 2012
    canada
    Ok Tom, I got the viewer working now. Havent got it switching screens yet, ill try that tomorrow.
    One more question, it seems like the Front and Side views are rotated? The Z axis should be vertical in these views but its horizontal on mine?
  8. #8
    May 2006
    Hi Mark,
    Those views were more for a Lathe. Please see if this patch for non-lathe mode works better for you. This has the Transform Change as well for V4.34:
    http://dynomotion.com/Software/Patch...KMotionCNC.exe
    http://dynomotion.com/Software/Patch...nterpreter.dll
  9. #9
    May 2012
    canada
    Hi Mark,
    Hi Tom,
    I finally got around to trying these files. When I hit front view or side view now, it just shows a green screen without any tool paths. I tried zooming out but cant seem to find the part again.
    I was able to create two separate screens and get them to switch between each other by clicking a button. This is working well
    One more thing, before I finish everything up with screen editor, would it be possible to add a "Next Tool" button? That would be very handy if it wasnt much trouble. Basically one button to click that would search for the next M06 and make that the next line. That would save me sooo much time when running certain operations over to bring things out to size. Thanks again.
    Mark
    - Also, machine has been running fine since, I will post back if it acts up again.
  10. #10
    May 2012
    canada
    Hi Tom,
    I didnt hear back from you on this last post. No big deal really about the g viewer views being rotated, i can still rotate it around and see what I need.
    Wondering if you think theres any easy way to add a "next tool" button. Thanks.
    Mark
  11. #11
    May 2006
    Hi Mark,
    Sorry for the delay we’ve been evacuated from the office for almost a week due to the fires here in California (Woolsey). But we were fortunate to not have any loss.
    We were able to duplicate the GViewer issue but don’t have a fix yet.
    Regarding next tool search:I’m trying to think of a general way to add such functionality. The Screen Editor has a means of sending Windows messages such as mouse clicks and keyboard keys. So I was going to see if a fixed sequence of messages would do what you desire. You might also look at a 3rd party keystroke Generator. I assume you realize there is a g code search feature.
  12. #12
    May 2012
    canada
    Hi Mark,
    Hi Tom, wow sorry to hear your that close to the fire. At least theres no loss, hopefully it stays that way. Wishing the best to all you guys down there. We had a small forest fire close to our home this summer and were evacuated for a day but thankfully they got things under control. Its not a nice feeling to have to just leave everything not knowing if there will be anything left to come back to.
    Yeah I know about the search feature and use it in larger programs. At my last job we used mastercam and their G-code editor has a next and previous tool button and it was very convenient to jump to next tool in a single click. I was thinking it would be awesome to have this in Kmotioncnc, would be super fast for finding tools and restarting part way through the program. See pic here: https://planet-cnc.com/wp-content/up...02/Slika14.jpg
    I downloaded AutoHotkey and created a script to find the next M06 using keyboard commands. Its a pretty neat little program. I setup Ctrl+Down and Ctrl+Up to search up and down and seems to work fine. Its fairly simple, see below. Is there any way to add a simple thing like this to Kmotioncnc or do i need to keep using the AutoHotkey program? Heres the script:
    ^Down::
    Send, ^f
    Send, m06
    Send, {Tab}
    Send, {Tab}
    Send, {Tab}
    Send, {Tab}
    Send, d
    Send, {Tab}
    Send, {enter}
    Send, {Tab}
    Send, {enter}
    return
    ^Up::
    Send, ^f
    Send, m06
    Send, {Tab}
    Send, {Tab}
    Send, {Tab}
    Send, {Tab}
    Send, u
    Send, {Tab}
    Send, {enter}
    Send, {Tab}
    Send, {enter}
    return
