How to abort MoveExp()
Results 1 to 2 of 2
Thread: How to abort MoveExp()
    Aug 2006
    Default How to abort MoveExp()
    quick question, what is a right way to abort motion of MoveExp() ? Should we use Jog(ch,0)?
    In my situation here is 2 axes - one following another with second loop which represent following error at output ch2->Output
    when follower is far away I use
    ch0->Dest += ch2->Output;
    which seems to give best response to large disturbances, but when I'm very close to target it produces overshoots and MoveExp() seems to be better.
    Intention is to write:
    if (ch2->Output < SomeLimit)
    MoveExp(ch0, ch2->Output * gain , TAU);
    } else
    Jog(ch0,0); // <================== is that good to abort unfinished MoveExp()?
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: How to abort MoveExp()
    Hi funding33,
    You can use Jog to zero (stop asap from current situation), or Move() to some position.
    I don't follow how you have things configured. Or why you would want to "abort the MoveExp()"
    But regarding your code:
    #1 - you probably would want an absolute value in the 'if' condition or:
    if (ch2->Output < SomeLimit && ch2->Output > -SomeLimit)
    #2 unlike MoveExp, Move or Jog should not be called continuously. Only call it once when needed or no sooner than every ~50ms since the last call.
    #3 the Jog(ch0,0) doesn't stop/abort motion instantly. Instead it plans a trajectory to come to a stop that will take time based on current velocity and Acceleration and Jerk limits. During this time ch0->Dest will be driven by this trajectory, so you should not also be changing it.
    You might try try tuning the ch0 axis with a Lead Filter or Derivative Gain to reduce overshoot.
