Hi Chris,
That looks like Status Data is somehow being mixed with Version data. That would more likely be a Version/Software/Mach3/Windows problem rather than a hardware problem with KFLOP.
Can you run KMotion.exe and request the Version from the Console? Can you Compile/Download/Execute C Programs with KMotion.exe?
You might check the registry entry used by Mach3 to find the correct Version of KMotion Libraries:
Use regedit to check if
\Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Wi ndows\CurrentVersion\App Paths\Mach3.exe contains a path entry to the \KMotion\Release directory of the installed version of KMotion.
