help urgent
Results 1 to 11 of 11
Thread: help urgent
    Default help urgent
    dear tom, I have a problem, the kflop has failed, I have already ordered a new one, can you send it as soon as possible? I have a test for next week, thanks moglianesi dalmazio
    Member TomKerekes's Avatar
    May 2006
    Default Re: help urgent
    Hi moglianesi,
    Sorry to hear this. We can ship it tomorrow (10/17). If you want it shipped faster than USPS Express International contact support and they can give you a quote for other methods.
    Regards
    TK http://dynomotion.com
    thanks tom, okay ups, I urgently got the kflop I had in Italy,the failed kflop no longer lights up, the power supplies are correct, the leds remain off and the recovery from alarm out of time
    May 2006
    Hi moglianesi,
    Ok.
    If the LEDs don't Flash with applied power that would indicate a bad, unrecoverable KFLOP.
    Any ideas on how the board got damaged? What were you doing when it failed?
    Regards
    I tried to connect a ttl encoder on the j6 connector, I think the fpga is dead, can I try to replace it?
    Quote Originally Posted by dmoglianesi View Post
    Br tom the dsp is cc tanks dalmazio
  7. #7
    May 2006
    Hi moglianesi,
    The pins on JP6 are 3.3V signals and shouldn't be driven higher than 3.8V. A 5V TTL signal or even a 5V Line Driver normally will not do this.
    It is usually not cost effective to repair boards like this. But if you wish to try the part number for U6 is a Xilinx:
    XC3S100E-4TQG144C
    I don't understand what "dsp is cc" means.
    Regards
  8. #8
    dear tom, u5 and shorted, I bought on ebay u5 and u6, I try to fix it, I have already unsoldered u5 and the short circuit disappeared, I ordered u5 and u6, I try to fix it, I hope the kanalog is not broken
  9. #9
    dear tom, unfortunately also the canalog and faulty, I have already ordered a new one, regards dalmazio
  10. #10
    dear tom, I'm trying to fix the kanalog, you can tell me the names of u32, u31u30, u24, u25, u26, u21, u27u18, u7, u11, I lost the document where I had noted the names, I bought a new kanalog but not I have time to wait for it to arrive, thanks dalmazio
  11. #11
    May 2006
    Hi moglianesi,
    Please ask this question to Dynomotion support.
    Regards
help urgent
help urgent
