ouput signal - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: ouput signal
  1. #13
    Oct 2014
    Default Re: ouput signal
    dear tom, with the program rs232read, can only communicate with the console kamotion that prints them in hexadecimal, and does not execute the command, how can I translate it because the axis moves with a command like move0 = 500 via serial rs232 tanks dalmazio
  2. #14
    Gold Member TomKerekes's Avatar
    May 2006
    Hi Dalmazio,
    Sorry I don't understand what you are doing or trying to do.
    If you want to have KFLOP receive Move commands from the RS232 port you will need to write a C Program that receives the command and parameter characters, converts the parameter characters to a value, then calls a C Function to Move.
    sscanf can be used to convert characters to a variable
    Move(0, value); can be used to move axis 0 to some destination
ouput signal
ouput signal
