Need Help! Regarding encoder input to kflop
Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Regarding encoder input to kflop
    Gold Member amitkumar171's Avatar
    Aug 2017
    India
    Default Regarding encoder input to kflop
    Dear all
    Presently we are using KFLOP board and KMOTION. And we need to find the simple Encoders. For Finding the Encoders we need to know:*
    1. what are the Communication Protocols supports KFLOP board and KMOTION for interfacing the Encoders?
    2. How many Encoders we can interface which supports KFLOP & KMOTION?
    3. Which type of Encoder interfacing you will suggest for the KFLOP?
    4.**Can we use EnDat 2.2 – Bidirectional Interface Type and TTL interface Type?
    Regards
    Sent from my Redmi Note 5 Pro using Tapatalk
    Regards
    Amit Kumar
    Registered TomKerekes's Avatar
    May 2006
    Default Re: Regarding encoder input to kflop
    Hi Amit,
    KFLOP only directly supports digital incremental encoders. See:
    http://dynomotion.com/faq.html#Encoders
    KFLOP has 8 encoder inputs. There are some pinout limitations based on your configuration. The Encoder input pins normally on JP7 and JP5 can be multiplexed over to KFLOP JP4 and JP6. See the MuxEncoders.c example.
    Differential digital incremental quadrature encoders
    No. Except sometimes they may include incremental quadrature signals.
    Regards
    Regards
    TK http://dynomotion.com
    Aug 2017
    India
    Hi Tom,
    Thanks for the information.
    As i was planning to use the following series of encoder from heidenhain.
    LC415/ LC485/ LF485/ LS487
    https://www.heidenhain.com/en_US/pro...lc-400-series/
    https://www.heidenhain.com/en_US/pro...-tools/lf-485/
    https://www.heidenhain.com/en_US/pro...ls-400-series/
    Please help me out with
    1. How to use the above encoders with the KLFOP/KANALOG ?
    2. Are these encoders compatible with KFLOP/KANALOG Board ?
    Waiting for your kind reply.
    Regards
    Amit Kumar
    May 2006
    Hi Amit,
    The encoders with the Incremental signals TTL would be compatible with KFLOP/Kanalog.
    From the Heidenhain Manuual:
    Regarding encoder input to kflop-heidmanual-png
    Connect:
    Heidenhain Ua1 to Kanalog A+
    Heidenhain Ua2 to Kanalog B+
    Heidenhain /Ua1 to Kanalog A-
    Heidenhain /Ua2 to Kanalog B-
    if the reference mark (Ua0 /Ua0) is required it may be connected to any spare A or B input
    KFLOP/Kanalog inputs have a max count rate of 1000000 quadrature counts per second. So for example if the resolution is 1um the max velocity would be 1 m/sec.
    Regards
    Regards
    Aug 2017
    India
    Hi Tom,
    Thanks for your reply.
    I will connect that encoder to Kanalog and will try to run.
    And also let you know if any problem occurs.
    Regards
    Amit Kumar
    Aug 2017
    India
    Ques - Can we use EnDat 2.2 – Bidirectional Interface Type and TTL interface Type?
    Ans - No. Except sometimes they may include incremental quadrature signals.
    Hi Tom,
    As you told "endat" communication not possible for encoders. But, I saw in KANALOG connector specs, in that mentioned Pin no. 15 of JP14 is CLK. So why this CLK pin and What is the frequency in this Pin?
    Regards
    Amit Kumar
  7. #7
    May 2006
    Hi Amit,
    That is a special clock used in a special manner involved with communicating data from KFLOP to Kanalog. It wouldn't be of any use for interfacing EnDat 2.2 encoders.
    Regards
    Regards
  8. #8
    Aug 2017
    India
    Hi Tom,
    Arrow mark shows, CLK is input to the KFLOP. Then How kanalog board providing CLK to KFLOP? Could you tell more.
    If we write the the code, Can we generate Clock from any other unused IO's (IO from JP4 or 5 or 6 or 7)? If yes, How much maximum frequency range i can generate?
    Regards
    Amit Kumar
  9. #9
    May 2006
    Hi Amit,
    No the Kanalog interface is complex and we don't have it documented and it is not likely to be of any use to you.
    Below is a program that generates a clock on IO16 with software and reads a bit each clock.
    It prints :Time per clock = 2.07 us, frequency = 483 KHz
    Code:
    #include "KMotionDef.h"
    #define CLK 16
    #define DATA 17
    void main()
        double T0, T1;
        int i = 0, k;
        SetBitDirection(CLK, 1);
        SetBitDirection(DATA, 1);
        T0 = Time_sec();
        for (k = 0; k < 8; k++)
            SetBit(CLK);            //Toggle Clock
            ClearBit(CLK);
            i = (i << 1) | ReadBit(DATA);    // Read one bit
        T1 = Time_sec();
        printf("Time per clock = %.2f us, frequency = %.0f KHz\n", (T1 - T0) * 1e6 / 8.0,
               1e-3 / (T1 - T0) * 8.0);
    Here is a scope of IO16. Note some clock irregularity due to cache and then 641KHz
    Regarding encoder input to kflop-scope-png
    Regards
  10. #10
    Aug 2017
    India
    Quote Originally Posted by TomKerekes View Post
    Hi Amit,
    Code:
    #define CLK 16
    #define DATA 17
    void main()
        double T0, T1;
        int i = 0, k;
        T0 = Time_sec();
            ClearBit(CLK);
        T1 = Time_sec();
    Dear Tom,
    You have mentioned the frequency 483kHz-641kHz. Why can't we generate more frequency like 1MHz-10MHz?
    What is the input clock frequency for the FPGA?
    Regards,
    Regards
    Amit Kumar
  11. #11
    May 2006
    Hi Amit,
    Because that is the time it takes the code to execute.
    The FPGA basically operates at 16.67MHz but has access to much higher clock rates. I'm sure the FPGA could be re-programmed to support EnDat 2.2 encoder compatibility. But this would involve developing VHDL code to support it as well as new KFLOP DSP firmware to support reading the absolute values and so forth. This would result in a custom specialized version. Also changes to the PC GUI and documentation. We don't release the FPGA configuration or have documentation to allow User to modify it. If you really require interfacing to these encoders we would consider developing the interface for you for an NRE charge of $10K.
    Regards
  12. #12
    Aug 2017
    India
    Hi Tom,
    I had some more doubts. They are as follows :
    1. In the FPGA datasheet it is mentioned that the operating frequency range is 5-300MHZ and 5MHz is the minimum. But like you said currently KFLOP- FPGA is working at <600KHz.
    I am sorry but I am a little confused here as to how the FPGA is working at a frequency less than the specified range.
    2. Is the FPGA being driven by an external clock? If yes, What is the input frequency presently?
    3. Also is the present firmware in C language? If yes, then why do we need to write a new VHDL code ? Why can't it be in C language only?
    Regards
    Amit Kumar
