Need Help! Cyclic USB connection
Results 1 to 12 of 12
Thread: Cyclic USB connection
    Apr 2018
    Ukraine
    Default Cyclic USB connection
    Hello. Burned chip U6 SPARTANXC3S100E, also burned U10 FTDI FT245RL.
    I replaced it with new ones.
    Made the FTDI firmware as specified here
    Now the computer sees KFLOP but in the program it tries to connect cyclically
    Cyclic USB connection-kmotion-konnect-gif
    Attached Thumbnails Attached Thumbnails Cyclic USB connection-kmotion-konnect-gif
    Member TomKerekes's Avatar
    May 2006
    Default Re: Cyclic USB connection
    Hi zaxtone,
    Have you tried performing Flash Recovery?
    Regards
    Regards
    TK http://dynomotion.com
    Apr 2018
    Ukraine
    May 2006
    Hi zaxtone,
    It seems other things on the board have also been damaged. Possibly outputs from the DSP used to enable and reset the FTDI chip. Or possibly a regulator (1.2V, 2.5V, 3.3V). I can't tell from your video if the board is resetting. You might try using an external 5V supply in the unlikely case that USB 5V isn't supplying enough current.
    Sorry it isn't normally cost effective to attempt repair of these boards.
    Regards
    Regards
    Apr 2018
    Ukraine
    After the U6 was burned and U10 was first replaced with U10, the connection was, but U6 did not all the axes work and some messed up.
    Then I changed U6 to a new one. Now I have this problem.
    May 2006
    Hi zaxtone,
    That would somewhat indicate that the replaced U6 (XC3S100E-4TQG144C) was bad or not installed correctly. The USB data passes through that device. Did you check carefully for bad solder connections or solder shorts?
    Regards
    Regards
  7. #7
    Apr 2018
    Ukraine
    In addition, all the conclusions were lost, stopped blinking. Now there are such messages
    Cyclic USB connection-1-jpg
    Next message
    Cyclic USB connection-2-jpg
    Attached Thumbnails Attached Thumbnails Cyclic USB connection-1-jpg   Cyclic USB connection-2-jpg
  8. #8
    May 2006
    Hi zaxtone,
    I don't understand. Those messages are different. What did you do differently?
    They indicate the hardware is all working correctly. You only need to Flash the New Version.
    Regarding your Private Message we are in Pacific Standard Time (California).
    Regards
    Regards
  9. #9
    Apr 2018
    Ukraine
    Is it possible to send a new board without elements.
    I would reinstall them to a new one
    I suspect that internal conductors could be damaged
  10. #10
    May 2006
    Hi zaxtone,
    I'm not sure I understand. But no, we don't sell bare boards without components.
    Regards
    Regards
  11. #11
    Apr 2018
    Ukraine
    The next problem
  12. #12
    May 2006
    Hi zaxtone,
    Congratulations
    You haven't created or configured your Init Program. You might watch this (7:58 configures the INIT button):
    Regards
    Regards
