Need Help! KFlop+KStep Lathe - G-code M06 ignores tool offsets
Results 1 to 4 of 4
Thread: KFlop+KStep Lathe - G-code M06 ignores tool offsets
    Jan 2008
    Finland
    Default KFlop+KStep Lathe - G-code M06 ignores tool offsets
    Dear Tom,
    I use a KFlop+KStep controlled small Sherline CNC-Lathe to turn some hardwood accessories for musical instruments. I have one tool cutting from the front and another from the back. This way I can run the whole g-code without changing tools.
    I used to do this with KFlop+KStep+Mach3 (it worked ok earlier, but somehow I can’t that to work anymore - no movement for some reasons), but I thought to start using KMotion as it works very well with my 3-axis gantry-router.
    But I run to a problem. The two cutting tools are fixed sufficiently far apart on the slide, so one doesn’t disturb the job while the other is cutting. These tools have certain offsets registered in the tooltable as “X offset” and “length” (=Z-direction). When I run the G-code, the correct tool number shows in the KMotionCNC screen, but the offsets are ignored. Only if I change the tool MANUALLY, do the offsets show correctly.
    Am I missing some setting? Or do I need some c-program to run when M06 happens?
    Thanks for your help.
    Eero
    Member TomKerekes's Avatar
    May 2006
    Default Re: KFlop+KStep Lathe - G-code M06 ignores tool offsets
    Hi Eero,
    Please see this article in our wiki.
    HTH
    Regards
    Regards
    TK http://dynomotion.com
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by eerohaahti View Post
    Dear Tom,
    Eero
    M06 is not for tool offset, M06 is for tool change, you need to use other G-Codes to address different tool offsets
    Mactec54
    Jan 2008
    Finland
    G43 solved my problem.
    Thanks for clearing this for me.
    All the best,
    Eero
