SBL Magnaturn Retrofit - Page 2
Page 2 of 8 FirstFirst 12345 ... LastLast
Results 13 to 24 of 96
Thread: SBL Magnaturn Retrofit
  1. #13
    Registered Need TECH Help!'s Avatar
    Dec 2007
    Default Re: SBL Magnaturn Retrofit
    Got some electrical components mounted....
    Attached Thumbnails Attached Thumbnails SBL Magnaturn Retrofit-topbox1-jpg   SBL Magnaturn Retrofit-topbox2-jpg   SBL Magnaturn Retrofit-topbox3-jpg   SBL Magnaturn Retrofit-custommiddlebox1-jpg
    SBL Magnaturn Retrofit-bottombox1-jpg
    http://www.homecncstuff.elementfx.com/
  2. #14
    Registered TomKerekes's Avatar
    May 2006
    Hi Troy,
    I see you kept the fan. Whats the plan for the door to the 3.5inch floppies to be used for?
    Help with identifiyng Southbend Magnaturn-southbend-bridgeport-cnc-lathe-004-jpg
    Regards
    TK http://dynomotion.com
  3. #15
    Dec 2007
    Hay Tom,
    Boy.... wish my lathe was as clean as the one in your picture The door will eventually have USB ports.
  4. #16
    Dec 2007
  5. #17
    May 2012
    canada
    Nice work on the electrical enclosure. I like your welding bench, how its enclosed and storage underneath. Do you have a fume extractor or something up top? I bet it would work really well like that.
  6. #18
    Dec 2007
    Quote Originally Posted by mmurray70 View Post
    Thanks.
    No, but there is a big exhaust fan in wall beside it that does the job very well. Now that you mention it i could easily duct to it and use a smaller fan for welding and such
  7. #19
    Dec 2007
    Here is a video of making the Zaxis Ballscrew nut for lathe. I used Fusion360 for the High Speed Toolpath code and using my Dynomotion retrofitted Hurco mill.
  8. #20
    Dec 2007
    Last but not least the Dynomotion boards are mounted.
    Attached Thumbnails Attached Thumbnails SBL Magnaturn Retrofit-boardsonrail-jpg
  9. #21
    Dec 2007
    Is the CNC Zone website no more? Had to post this on IndustryArena.
  10. #22
    Dec 2007
    I have a 240VAC to 120VAC single phase control transformer(open frame). Do i ground it at the frame of transformer?
    Troy
  11. #23
    Dec 2007
    Quote Originally Posted by Need TECH Help! View Post
    Try this one again. Think it got lost when i used the IndustryArena.
  12. #24
    Dec 2007
    Troy
