Hi Amit,
Do you have the Thread configured to launch on Power up?
See:
Configuration Screen
Regards
Hi, Tom
I am using Kflop Estop button it is wired on bit no 16 of JP4
It is working and program for this is flashed onto kflop board.
But after power reset if Estop is enabled still all axis are working.
flashed initialize program is not checking for EStop bit.
How to make estop bit checking enable everytime when i power up the machine. ?
waiting for your kind reply
THANK YOU
Regards
Amit Kumar
Hi Amit,
See:
Regards
Regards
TK http://dynomotion.com
Hi Amit,
Did you set Launch Thread #1 on Power Up before you Flashed User Data?
Did you check if the Thread is running after you cycle power?
Connect the USB, run KMotion.exe, check the C Programs Screen to see if there is a Green Bar over Thread #1.
Regards
Regards
