How to set arbitrary encoder position in C file
Results 1 to 6 of 6
Thread: How to set arbitrary encoder position in C file
    Aug 2006
    Default How to set arbitrary encoder position in C file
    quick Q:
    how do we set arbitrary encoder position when homing in C file instead of Zero(ch)?
    is that right:
    DisableAxis(CHNO_X);
    chan[CHNO_X].Position = -0.1234567E+8; // X init point
    EnableAxis(CHNO_X);
    Jun 2004
    Scotland
    Default Re: How to set arbitrary encoder position in C file
    you want to use EnableChanDest(int ch, double Dest).
    So from your post -
    Code:
    EnableChanDest(CHNO_X, -0.123456E+8); X init Point
    Member TomKerekes's Avatar
    May 2006
    I think it is actually Axis not Chan
    Code:
    EnableAxisDest(CHNO_X, -0.123456E+8); // X init Point
    Regards
    TK http://dynomotion.com
    Jun 2004
    Scotland
    You could well be right, and that would explain why my lathe still occasionally disables due to following error during initialisation...
    Aug 2006
    That does not work. It alters destination but not current position. Verified this on console. "Pos" reads the same value before and after EnableAxisDest:
    Attachment 392523
    Jun 2004
    Scotland
    I've not got a KFlop handy to test, but I thought that function should set the position to match the destination.
    You may need to use
    Code:
    ch0->position=-0.123456E6;
    However, AFAIK you can't use a constant to select the channel number, and I'm not sure if you'd also have to set the destination to match before enabling.
  7. #7
    Aug 2006
    that is same as was suggested in initial header post. "chan[CHNO_X].Position" type syntax allows to put some definition in to [] braces. And later "EnableAxis" seems to reset destination to current Pos. All looks to be working but lets wait confirmation from TomKerekes if there is no underwater stones doing so.
  8. #8
    Jun 2004
    Scotland
    So it is.
    In my defence, I've had a hard day!
    As long as it's updating the values how you want, then it's fine.
    I'm assuming you're now using chan[CHNO_X].Position to set the position, followed by EnableAxisDest[CHNO_X] to enable at the value you want?
