Unclear behaviour of VAR field in USER_Buttons setting tab
Results 1 to 4 of 4
Thread: Unclear behaviour of VAR field in USER_Buttons setting tab
    Aug 2006
    Default Unclear behaviour of VAR field in USER_Buttons setting tab
    It looks like before executing preset user button action to execute C programm the ActionIndex is writtent the persistVariable[VAR]. Why and what for is that?
    Strangelly the offset is user defined as the value of VAR field, while value written to board is hardcoded to be ActionIndex.
    Any explanation? How can we be sure it will not overwrite some persist variable used by other threads/programs?
    Member TomKerekes's Avatar
    May 2006
    Default Re: Unclear behaviour of VAR field in USER_Buttons setting tab
    Hi funding33,
    The Action Index is passed as a parameter so a C Program might determine which Action invoked it. This allows you to have multiple Actions use the same C Program which might simplify things in certain cases. See the Exec Prog description here.
    The Var field allows you to use any Variable you wish.
    You must keep track of which persist Variables are being used for which purpose. Its ok to use the same variable for multiple programs as long as they don't use the same variable at the same time.
    HTH
    Regards
    Regards
    TK http://dynomotion.com
    Aug 2006
    ok, clear. And (-1) seems to be a way to disbale this feature when not required. Thanks.
    May 2006
    You are correct.
    Regards
