i use version KMotion434k
Hi i finish to setup and make homing on my machine but got some issue whit soft limit switch
on Z-axi i got 250 encoder cont over shoot on soft limit ,that not critical just anoing
but on X axis the soft limit not work ! ,debug console tell me limit reach and go into feed hold ,but motor still move until physically spindle hit rotary table
any idea ? i try many may option for LimitSwitchOptions=0x whit similar result
Best regard Marc Alphatronique
that config i use
#include "KMotionDef.h"
// Configuration and Homing program for a 3 axis System
// Limit switches are disabled and used as a home switch
// then they are re-enabled
main()
int SaveXLimits,SaveYLimits,SaveZLimits; //place to save limit switch settings
DisableAxis(0); // Disable all axes
DisableAxis(1);
DisableAxis(2);
// Set the axis parameters here
// after everything is configured in the KMotion Screens
// use copy C Code to clipboard on the configuration screen
// then paste here. Repeat for each axis
WriteSnapAmp(SNAP0+SNAP_PEAK_CUR_LIMIT0,10);
WriteSnapAmp(SNAP0+SNAP_PEAK_CUR_LIMIT1,10);
ch0->InputMode=ENCODER_MODE;
ch0->OutputMode=DC_SERVO_MODE;
ch0->Vel=100000;
ch0->Accel=2e+06;
ch0->Jerk=900000;
ch0->P=30;
ch0->I=0;
ch0->D=10;
ch0->FFAccel=0;
ch0->FFVel=0;
ch0->MaxI=200;
ch0->MaxErr=500;
ch0->MaxOutput=200;
ch0->DeadBandGain=1;
ch0->DeadBandRange=0;
ch0->InputChan0=8;
ch0->InputChan1=0;
ch0->OutputChan0=8;
ch0->OutputChan1=0;
ch0->MasterAxis=-1;
ch0->LimitSwitchOptions=0x120;
ch0->LimitSwitchNegBit=0;
ch0->LimitSwitchPosBit=0;
ch0->SoftLimitPos=100;
ch0->SoftLimitNeg=-290000;
ch0->InputGain0=1;
ch0->InputGain1=1;
ch0->InputOffset0=0;
ch0->InputOffset1=0;
ch0->OutputGain=1;
ch0->OutputOffset=0;
ch0->SlaveGain=1;
ch0->BacklashMode=BACKLASH_OFF;
ch0->BacklashAmount=0;
ch0->BacklashRate=0;
ch0->invDistPerCycle=1;
ch0->Lead=0;
ch0->MaxFollowingError=1000;
ch0->StepperAmplitude=20;
ch0->iir[0].B0=1;
ch0->iir[0].B1=0;
ch0->iir[0].B2=0;
ch0->iir[0].A1=0;
ch0->iir[0].A2=0;
ch0->iir[1].B0=1;
ch0->iir[1].B1=0;
ch0->iir[1].B2=0;
ch0->iir[1].A1=0;
ch0->iir[1].A2=0;
ch0->iir[2].B0=1;
ch0->iir[2].B1=0;
ch0->iir[2].B2=0;
ch0->iir[2].A1=0;
ch0->iir[2].A2=0;
ch1->InputMode=NO_INPUT_MODE;
ch1->OutputMode=STEP_DIR_MODE;
ch1->Vel=10000;
ch1->Accel=400000;
ch1->Jerk=4e+06;
ch1->P=0;
ch1->I=0.01;
ch1->D=0;
ch1->FFAccel=0;
ch1->FFVel=0;
ch1->MaxI=200;
ch1->MaxErr=1e+06;
ch1->MaxOutput=200;
ch1->DeadBandGain=1;
ch1->DeadBandRange=0;
ch1->InputChan0=0;
ch1->InputChan1=0;
ch1->OutputChan0=5;
ch1->OutputChan1=0;
ch1->MasterAxis=-1;
ch1->LimitSwitchOptions=0x100;
ch1->LimitSwitchNegBit=0;
ch1->LimitSwitchPosBit=0;
ch1->SoftLimitPos=1e+06;
ch1->SoftLimitNeg=1e+06;
ch1->InputGain0=1;
ch1->InputGain1=1;
ch1->InputOffset0=0;
ch1->InputOffset1=0;
ch1->OutputGain=1;
ch1->OutputOffset=0;
ch1->SlaveGain=1;
ch1->BacklashMode=BACKLASH_OFF;
ch1->BacklashAmount=0;
ch1->BacklashRate=0;
ch1->invDistPerCycle=1;
ch1->Lead=0;
ch1->MaxFollowingError=20;
ch1->StepperAmplitude=20;
ch1->iir[0].B0=1;
ch1->iir[0].B1=0;
ch1->iir[0].B2=0;
ch1->iir[0].A1=0;
ch1->iir[0].A2=0;
ch1->iir[1].B0=1;
ch1->iir[1].B1=0;
ch1->iir[1].B2=0;
ch1->iir[1].A1=0;
ch1->iir[1].A2=0;
ch1->iir[2].B0=1;
ch1->iir[2].B1=0;
ch1->iir[2].B2=0;
ch1->iir[2].A1=0;
ch1->iir[2].A2=0;
ch2->InputMode=ENCODER_MODE;
ch2->OutputMode=STEP_DIR_MODE;
ch2->Vel=10000;
ch2->Accel=400000;
ch2->Jerk=4e+06;
ch2->P=0;
ch2->I=0.01;
ch2->D=0;
ch2->FFAccel=0;
ch2->FFVel=0;
ch2->MaxI=200;
ch2->MaxErr=1e+06;
ch2->MaxOutput=200;
ch2->DeadBandGain=1;
ch2->DeadBandRange=0;
ch2->InputChan0=0;
ch2->InputChan1=0;
ch2->OutputChan0=4;
ch2->OutputChan1=0;
ch2->MasterAxis=-1;
ch2->LimitSwitchOptions=0x110;
ch2->LimitSwitchNegBit=0;
ch2->LimitSwitchPosBit=0;
ch2->SoftLimitPos=100;
ch2->SoftLimitNeg=-27000;
ch2->InputGain0=-2.5;
ch2->InputGain1=1;
ch2->InputOffset0=0;
ch2->InputOffset1=0;
ch2->OutputGain=1;
ch2->OutputOffset=0;
ch2->SlaveGain=1;
ch2->BacklashMode=BACKLASH_OFF;
ch2->BacklashAmount=0;
ch2->BacklashRate=0;
ch2->invDistPerCycle=1;
ch2->Lead=0;
ch2->MaxFollowingError=20;
ch2->StepperAmplitude=20;
ch2->iir[0].B0=1;
ch2->iir[0].B1=0;
ch2->iir[0].B2=0;
ch2->iir[0].A1=0;
ch2->iir[0].A2=0;
ch2->iir[1].B0=1;
ch2->iir[1].B1=0;
ch2->iir[1].B2=0;
ch2->iir[1].A1=0;
ch2->iir[1].A2=0;
ch2->iir[2].B0=1;
ch2->iir[2].B1=0;
ch2->iir[2].B2=0;
ch2->iir[2].A1=0;
ch2->iir[2].A2=0;
// disable the limits (first save how they were set)
SaveXLimits = ch0->LimitSwitchOptions;
SaveYLimits = ch1->LimitSwitchOptions;
SaveZLimits = ch2->LimitSwitchOptions;
// ch0->LimitSwitchOptions = 0;
// ch1->LimitSwitchOptions = 0;
// ch2->LimitSwitchOptions = 0;
// enable all 3 axes and begin servoing where we are
EnableAxis(0);
EnableAxis(1);
EnableAxis(2);
// Home Z up first - jog until it sees the limit
ch2->SoftLimitPos=270000;
ch2->SoftLimitNeg=-270000;
Jog(2,500); // jog slowly positive
while (!ReadBit(76)) ; // loop until IO bit goes high
Jog(2,0); // stop
while (!CheckDone(2)) ; // loop until motion completes
DisableAxis(2); // disable the axis
Zero(2); // Zero the position
ch2->SoftLimitNeg=-26000;
EnableAxis(2); // re-enable the ServoTick
Move(2,-1000.0); // move some amount inside the limits
//ch2->LimitSwitchOptions = SaveZLimits; // restore limit settings
// Home X next - jog until it sees the limit
ch0->SoftLimitPos=290000;
Jog(0,1000); // jog slowly negative
while (!ReadBit(77)) ; // loop until IO bit goes high
Jog(0,0); // stop
while (!CheckDone(0)) ; // loop until motion completes
DisableAxis(0); // disable the axis
Zero(0); // Zero the position
EnableAxis(0); // re-enable the ServoTick
Move(0,-1000.0); // move some amount inside the limits
//ch0->LimitSwitchOptions = SaveXLimits; // restore limit settings
// Home Y next - jog until it sees the limit
// Jog(1,-100); // jog slowly negative
// while (!ReadBit(9)) ; // loop until IO bit goes high
// Jog(1,0); // stop
// while (!CheckDone(1)) ; // loop until motion completes
// DisableAxis(1); // disable the axis
// Zero(1); // Zero the position
// EnableAxis(1); // re-enable the ServoTick
// Move(1,1000.0); // move some amount inside the limits
ch1->LimitSwitchOptions = SaveYLimits; // restore limit settings
// DefineCoordSystem(0,1,2,-1); //Define XYZ coordinated motion axes
Hi Marc,
Strange. I'm not sure why. Here are some things to check:
The Soft Limits issue a Feedhold which only stops the Axes defined in the Coordinated Motion System. I see you have your
//DefineCoordSystem(0,1,2,-1); //Define XYZ coordinated motion axes
commented out. Did you exclude X from the Coordinated Motion System? Please define the Coordinate System.
Have you Flashed any changes to KFLOP? If so please restore by doing a "New Version".
I see Axis 1 has the Neg Limit set to a Positive number. This may trigger an immediate Feedhold when enabled.
Please check that your Init program actually finishes and the Soft Limits are set properly.
Regards
Regards
TK http://dynomotion.com
Hi
system init and the tread end so that part seem good
Ch1 not have or use limit Switch it a rotary table "A" axis
will test Coordinated Motion System
i commented it since not idea what that do , have assumed that is for G-code part and not yet a that step , so probably bad idea ;-)
ok uncommnet the DefineCoordSystem(0,1,2,-1) and still same issue ,and i able to move 30000 over the limit that is ~1 feet !!
Hi Marc,
So your resolution is ~ 2500 counts/inch?
You are commanding a Velocity of 100000 counts/sec. That's 40ips (2400ipm). Can your system really move that fast??
You are also specifying a fairly low Jerk of 900000 counts/sec^3. With these settings you are forcing KFLOP to accelerate and decelerate over ~ 1 foot.
Here is a plot of your settings. Notice it takes about 35000 counts to accelerate and 35000 counts to decelerate:
Can you reduce your Max Velocity and increase Jerk to allow KFLOP to stop in a shorter distance?
Regards
Regards
HI this may help figure the machine no extremely fast i slow down speed
on the X each encoder count = 6um
the hight velocity come from the 5,000 cont encoder so Kflop see 20,000 per revolution , 6 feet of travel = ~290,000 cont
so 4027 count per inch
i must admit that the "jerk" confuse me a bit ..
Best regard
have increase jerk ,move start to be bit bit violent and got axi following error
it bit help a bit but still 16000 cont so 4" , need to be under 1/2" or better
did the trajectory planet on the CNC soft help a bit on this ?? i try to have fist layer reliable before put G-code over head
i end up whit 1/2 delrin rod as shock absorber for avoid spindle hit
increase jerk and velocity and even slower accel and still need significant deceleration time
Hi Mark,
It seems your system really needs a large distance to start and stop.
In this case you can add a User Program that will monitor Velocity, Acceleration, and Distance to the Soft Limits to begin stopping before reaching the Soft Limits.
See the AdjustSoftLimits.c and AdjustSoftLimitsTest.c examples.
Here is the code you will need to add:HTHCode:#include "KMotionDef.h" #include "AdjustSoftLimits.c" // tests functionality of adjusting softlimits feedhold based on // Velocity and Acceleration using the CheckDistToStop Calculations main() { for (;;) { WaitNextTimeSlice(); CheckDistToStop(ch0); CheckDistToStop(ch2); } }
Regards
Regards
