Need Help! Error in Drilling Cycle G83 - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Error in Drilling Cycle G83
  1. #13
    Gold Member amitkumar171's Avatar
    Aug 2017
    India
    Default Re: Error in Drilling Cycle G83
    Hi all,
    I was talking about Multi Axis Drilling Holes in Arbitrary plane.
    Check this article is this possible in Kflop too ?
    https://www.linkedin.com/pulse/fanuc...-tim-markoski/
    This feature Tilted work planes adds extra functionality to controller other than tcp for all type of 5 axis cutting and drilling.
    if this feature can be updated to Kflop then it would be great.
    waiting for your kind reply.
    Regards
    Amit Kumar
  2. #14
    Gold Member TomKerekes's Avatar
    May 2006
    Hi Amit,
    You didn't respond to any of the previous suggestions.
    I don't think your G83 issue has anything to do with 5-axis control. All your G83 GCode doesn't make sense. Even your "good" GCode that doesn't give an error has zero depth.
    Regards
    TK
    http://dynomotion.com
  3. #15
    Aug 2017
    India
    Quote Originally Posted by TomKerekes View Post
    Hi Amit,
    Regards
    Hello Tom,
    i have replied to every suggestion given by you....In fact I ran my machine only after taking in your suggestions and making alterations accordingly.
    I have run the G83 code on my machine and it works perfectly fine, the only modification I had to do was to add a g18 command before it.
    Regards
    Amit Kumar
