Adding a 4th axis and have a few questions... - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 49
Thread: Adding a 4th axis and have a few questions...
  1. #37
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Adding a 4th axis and have a few questions...
    Hi mmurray70,
    Thanks for posting back. Sorry about that, We should have included a link. Version 4.34k introduced a bug with the screen editor when buttons invoke actions so we are reluctant to advertise it for general use. There is a patch if it effects you:
    http://dynomotion.com/Software/Patch...nterpreter.dll
    Regards
  2. #38
    May 2012
    canada
    Tom, i noticed another issue with 4.34k. When i press F9 to start spindle it does not start? Seems to be executing my init file instead for some reason? Any ideas?
  3. #39
    May 2006
    Hi mmurray70,
    I suspect the Hot Key for your Init User button is probably configured as F9 (Keycode 120). Our bad for configuring that as a default example. Change User Button Hotkey to -1 or some other Hotkey to restore F9 for the Spindle On. See:
    Tool Setup Screen User Buttons
    Adding a 4th axis and have a few questions...-customactions-jpg
    Regards
  4. #40
    May 2012
    canada
    Hi Tom,
    I just checked and hotkey is already set to -1. Any other ideas?.
  5. #41
    May 2006
    Hi mmurray70,
    Strange. I tested here and with the Init Hotkey set to 120 I had the problem and changing to -1 no longer did. Please post a screen shot of your Tool Setup Screens so we can check and try to duplicate. Are you using a custom screen script?
    Regards
  6. #42
    May 2012
    canada
    Got it working now. Not sure why -1 wouldnt work, but i changed init user button to the code for F8, i think it might have been 119. And now f9 works properly to start spindle. So even though it was showing -1 for init hotkey it was still using F9 for some reason. Oh well at least its working now. Thanks again
  7. #43
    May 2012
    canada
    Tom, looks like theres still an issue here with the hotkeys. Seems like its not actually loading the values I have entered for the hotkeys for some reason.
    When i first load kmotioncnc, F9 still runs init instead of starting my spindle. And i have the insert key configured to set tool length offset, this doesnt work either. Just does nothing when i push insert. If I simply hit Tool setup, go to user buttons and hit ok, without even changing anything, it all works perfectly.
    If i exit kmotioncnc and open again same thing, F9 runs init and my tool length "insert" key does nothing until i go to user button page and hit OK. I am using a custom screen, not sure if this could be related. Strange nobody else has ran into this.
  8. #44
    May 2006
    Hi mmurray70,
    I suspect the Screen Script is the issue. The User Button Hot Keys in the Screen Script, and the Hot Keys in the Tool Setup, are probably are in conflict. So when KMotionCNC starts up and loads the Screen Script they are set as in the Screen Script. When Tool Setup closes they change to what's currently set in Tool Setup. Something we hadn't properly considered which is confusing. I see Hide/Show of the User Buttons has a similar issue. We'll work on coming up with a better solution. We're open for ideas. For now please try setting the Screen Script to match what you desire.
    Regards
  9. #45
    May 2012
    canada
    That was the problem. I didnt realize the hotkeys were also specified by screen editor. Yeah seems like you might want to set all this info under tool setup and just have the screen editor change the position/appearance of the buttons only.
    Its all working good for now with the numbers from tool setup and custom screen matching up.
  10. #46
    May 2012
    canada
    Quote Originally Posted by TomKerekes View Post
    Hi mmurray70,
    That looks reasonable to me. Except the Integrator limit might be still set low at 400 DAC counts when sometimes 1200 DAC counts is required to do the motion.
    I normally use a 2nd order low pass filter with Q=1.4
    Nice. Waiting for the Video
    Regards
    Everythings working great now Tom, Took a little video tonight of a part I was running, sorry for the wait. Program isnt optimized, only needed 5 parts but shows the 4th axis working well. This was just an indexing job, not full fourth but still cool. Its locking and unlocking with M codes that are included with post processor. Dont have to edit the code at all.
    Heres a link to video on my google drive. Let me know if this doesnt work. Also attached a pic of the part after finishing this operation. https://drive.google.com/file/d/1icX...ew?usp=sharing
    Attached Thumbnails Attached Thumbnails Adding a 4th axis and have a few questions...-20180804_205415-jpg
  11. #47
    May 2006
    Hi mmurray70,
    Beautiful. Do you mind if we put that on our YouTube Channel?
    But you forgot to do the rigid tapping.
  12. #48
    May 2012
    canada
    Yeah sure if you want. Try and save it somehow as I may end up deleting it from google drive someday. Im wishing now that I had fixed up the program and moved tools closer together to make it look more impressive. The orientation failed once in that video too lol. Thats due to old VFD though, not the control.
    No rigid tapping sorry. Those are NPT ports and I get a nicer finish thread milling then I do with a tap. The thread milling is at 2:30. This part would probably have been fine with a tap thought since its only aluminum. I use the rigid tapping all the time for normal threads, working great.
