Kflop right for me? - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Kflop right for me?
  1. #13
    Mar 2003
    Default Re: Kflop right for me?
    Try increasing the microstepping on the drives.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  2. #14
    Jun 2004
    Scotland
    As Gerry suggests, changing the microstepping is the easiest option to try.
    Resonance is where modern digital drives excel, as they'll try their best to compensate to avoid it (best I know of are currently Leadshine EM or AM series drives). Even by fitting encoders, the KFlop can't do much about resonance as it's a result of the interaction between the driver, and the motor. The only thing an encoder can achieve in that situation is to tell things are resonating.
    However, the main cause is likely to be the fact you're using Nema 34 motors. Most of these really need high voltage drives to get the best from them, as they typically have relatively high inductance.
    Using a higher voltage will usually mean the resonance occurs at a faster speed, which can mean it's less of a problem, as resonance is often amplified by the motors load.
    If you are going to start changing drivers, it can be worth swapping to Nema 23/4 motors. You can often get better performance from a smaller motor spinning faster, than you can from a bigger motor spinning slower.
  3. #15
    Gold Member TomKerekes's Avatar
    May 2006
    Hi Badarzewska,
    Size 34 motors have large mass and therefor lower resonant frequencies (no one tried answering my puzzle in post 7). Adding KStep or Encoders is not likely to help. Some advanced drives with anti-resonant damping may help some amount. Although the Wantai drives seem to claim to do this.
    Consider going to Servos for smooth and high performance.
    Regards
    TK
    http://dynomotion.com
Kflop right for me?
Kflop right for me?
