What errors are you getting? Why not use VS2015? What Version are you trying to use?
I am working with Dynomotion KMotion Controllers, where I can check, edit my Kinematics value in Visual Studio 2015 only.
If we use newer versions of Visual Studio for the Kinematics, the compilers during build Solution shows Tons of Errors.
Can somebody help me with the above Problem and explain me why it is coming.
Note: The same Kinematic code works fine in Visual Studio 2015.
Regards
TK http://dynomotion.com
