Build Thread Tree325 Retrofit Started - Page 23
Page 23 of 23 FirstFirst ... 1320212223
Results 265 to 269 of 269
Thread: Tree325 Retrofit Started
  1. #265
    Registered PeterTheWolf's Avatar
    Aug 2008
    Default Re: Tree325 Retrofit Started
    Quote Originally Posted by Greg9504 View Post
    OK DC bus voltage is sqrt 2 * supply voltage. In this case ~240v * sqrt 2 = 340 v
    So you are seeing a little over this on deceleration.
    When the motor decelerates that energy needs to go somewhere. Basically the VFD turns the motor into a generator and has to dump the excess energy. If the inertia load on the motor is large enough then the VFD can't dissipate the energy fast enough without some external means of absorbing the energy (a braking resistor). Is the spindle motor connected to any type of tool or tool holder attached to it? If so try the tests again without the tool/holder attached.
    What are P2.10, and P6.17 set to?
    Can you post a picture of the spindle motor nameplate? I too am wondering why P0.02 is set to 400Hz.
    As to why this was 'working' before, I'm not sure. Maybe the previous owner machining needs were simple and never needed to vary the spindle speed. Or maybe this is one of the reasons they sold it. Have you called them and asked? It does seem that you need a braking resistor. You could try to disable P6.05 but as I said before this may damage the drive. I would ask Automation Direct technical support what can happen if P6.05 is disabled without fitting a braking resistor.
    Greg9504,
    Currently:
    P2.10 = 00 (Control Mode, V/Hz without encoder feedback)
    P6.17 = 390.0 (Over-Voltage Stall Prevention Level, 230V series - 330.0V to 450.0V)
    I have tried to get a picture and/or reading the spindle motor nameplate via mirror on an extendable shaft. Both methods proved worthless. It looks like nameplate is made of aluminum and values are stamped into the aluminum which makes it very hard to read 10" down in the machine frame.
    For me to get the readings correctly I would need to the remove the pulleys belts and then hoist the motor fame up out of the machine frame. I have read this is no easy task without an overhead crane as it is very heavy.
    The machine at this point is still on a wood pallet and I do not think I have enough ceiling height in the garage lift it up enough. I had to lower the spindle quill down just to clear the 7" garage door opening with a pallet jack.
    I think I will need to find a Borescope to borrow or find one inexpensive enough to purchase for this one time use.
    I will see what I can do. I will also check into the what Automation Direct support has to say.
    Thanks,
    J325 Quick Links:
    Machine
    Existing Machine Schematics
    Electronic Cabinet-Right Side
    Electronic Cabinet-Back SIde
    Existing Drive Board SD1525-10
    J325 Servo Drive-SD1525 Manual
    3-Phase Rotary Convert Used
    RickB's J325 Retrofit Wiring
    KFLOP 5VDC/15Watt/3A Power Supply
    KANALOG Mounted & Connected
    Kmotion - Axis Encoder Manual Test of Position via Manual Movement
    Kanalog-Encoder Voltage High/Low Checks & 1KOhm Resister
    Kmotion Configuration Screens "RUN-AWAY"
    Tree Journeyman 325 Designed Specs.
    Tree Journeyman 325 Axis-Tension Frequency Settings
    Final Axis Tuned Error Parameters
    VFD Wiring to Existing Tree325 Old Controller
    DAC Values to RPM / Voltage Checks
  2. #266
    Jun 2013
    If you can slide a camera down beside the nameplate you may be able to photograph it. A mirror might also work.
    Ben
    Sent from my HTC6525LVW using Tapatalk
  3. #267
    May 2012
    canada
    Quote Originally Posted by PeterTheWolf View Post
    Thanks,
    Those dirt cheap USB ones on ebay for like $10 or something work ok for the price. Just plug them into your phone and download a camera app.
    I dont think id bother to take anything apart if you cant find it. Its obviously a 4 pole motor (1750 rpm) based on your measured speeds. And its almost certainly 60hz unless the machine was made in the UK sometimes you see 50hz. Definitely wouldnt be 400 for a typical induction motor like this machine would have. Even if you did mistake the 50/60 cycle thing it would just mean your V/hz would be off slightly and you could possibly be loosing a little power or running slightly hot, probably not even noticeable. And current is somewhat constant for a given HP 240v motor, you could estimate this fairly close too
  4. #268
    Jun 2013
    Sorry I missed that you already tried that.
    Ben
  5. #269
    Gold Member TomKerekes's Avatar
    May 2006
    Hi PeterTheWolf,
    BTW regarding Braking Resistor: I see Digikey has a 300W continuous 20ohm resistor for $18. If it were me I'd risk trying it. The data sheet says it can withstand 3KW for 5 seconds. I don't know the energy of your rotating mass but I doubt that it is so much to be a problem. Unless you repeatedly do back-to-back start stops. You could experiment to see how warm/hot it gets after one stop, then two stops, etc...
    Part Number FVE030020E20R0KE
    https://www.digikey.com/product-deta...0-20-ND/269994
    Please be safe. 350VDC is absolutely lethal.
    Regards
    TK
    http://dynomotion.com
