Build Thread Tree325 Retrofit Started - Page 20
Page 20 of 26 FirstFirst ... 1017181920212223 ... LastLast
Results 229 to 240 of 303
Thread: Tree325 Retrofit Started
  1. #229
    Registered PeterTheWolf's Avatar
    Aug 2008
    Default Re: Tree325 Retrofit Started
    Quote Originally Posted by mmurray70 View Post
    Do you think youll need to use M4 as well? Might take a few more steps on your machine since it involves reversing DAC signal. I was thinking we could set a variable or bit in the M3/M4 programs that the spindle.c program could use to check direction and then send the proper DAC value.
    Yes, I would like to get the "M4" working as well via NC code.
    Is there a means of debugging "C" code in Kmotion? Like see what value variables are? Seeing what the variables change too as the "C" code runs? Is there as way of test "C" code via step-by-step as it is run?
    This looks just like another steep learning curve.
    J325 Quick Links:
    Machine
    Existing Machine Schematics
    Electronic Cabinet-Right Side
    Electronic Cabinet-Back SIde
    Existing Drive Board SD1525-10
    J325 Servo Drive-SD1525 Manual
    3-Phase Rotary Convert Used
    RickB's J325 Retrofit Wiring
    KFLOP 5VDC/15Watt/3A Power Supply
    KANALOG Mounted & Connected
    Kmotion - Axis Encoder Manual Test of Position via Manual Movement
    Kanalog-Encoder Voltage High/Low Checks & 1KOhm Resister
    Kmotion Configuration Screens "RUN-AWAY"
    Tree Journeyman 325 Designed Specs.
    Tree Journeyman 325 Axis-Tension Frequency Settings
    Final Axis Tuned Error Parameters
    VFD Wiring to Existing Tree325 Old Controller
    DAC Values to RPM / Voltage Checks
  2. #230
    May 2012
    canada
    Post the edited m3 and spindle.c programs your using now and ill see if i can help with getting reverse working.
    C programming will take a little while to learn, but I found it very rewarding in the end to be able to control my machine the way i can now. There is lots of tutorials out there, try and learn the very basics and then look at sample programs. Your machine wont be too bad anyway. You dont have a toolchanger or anything so it should go smoothly. The most your really going to want to be doing is maybe adding some buttons, overrides and a MPG and your done. There are many examples of this so most of it will be simply copy and paste and change a few numbers.
    You can print variables to console in kmotion (not kmotioncnc). Im not sure how to run it step by step or how to debug properly. Honestly i just setup the files to run in kmotioncnc and try it. If it gives me an error i go back and look for it. Might not be the proper way but I did manage to get everything working eventually.
  3. #231
    Gold Member TomKerekes's Avatar
    May 2006
    Hi PeterTheWolf,
    I want to try to use Kanalog to control one of the existing Tree 24VDC relays, so I purchase a small cheap relay that uses about 7.1mA to engage it if I calculated correctly; however, I am not sure how to connect this to Kanalog for the signal to switch it on.
    This is how I think it should be connect:
    Tree325 Retrofit Started-kanalog_relay_connections-jpg Link to the Image << ------ >>Here is Link to the Relay
    Does this look correct??
    As murray70 points out the relay drivers only switch to ground. They only sink current they do not source current as I believe that module requires, There are several solutions: #1 drive the original relay directly with the Kanalog Relay drivers. #2 use a 3.3V output from Kanalog JP12 which can sink/source current. #3 hard wire the relay module signal input to 5V and switch its GND connection with the Kanalog Relay Driver. I recommend Option #3. See below for the connections:
    Tree325 Retrofit Started-kanalogrelay-jpg
    Single stepping through code isn't usually practical as the code usually needs to run real-time.
    It can be helpful to build your program incrementally. In other words add functionality bit by bit and check that each newly added item works before going to the next.
    You can add printf statements to print messages to the Console Screen, ie. printf("M3 program started\n"); and/or time delays, ie. Delay_sec(3.0); to help show what things executed and what any values were.
    Another trick is to set an unused Axis Destination to a value, ie. ch7->Dest=spd; You can then watch this speed value on the Axis screen as the Axis 7 Destination.
    Regards
  4. #232
    Aug 2008
    Quote Originally Posted by TomKerekes View Post
    Thanks Tom ... I just tried Option #3 .... and it Worked; however, I will need to turn the "FET Driver 0" on and off as "OPTO Out 7" goes on and off I think.
    Then I think the following will work. However, I still need to prove this.
    Quote Originally Posted by PeterTheWolf View Post
    The way I understand it should work on terminal DI2 on the VFD terminal is:
    The +24VDC terminal on the VFD provides DI2 terminal with +24VDC. At least that is what I tested with along with a 1K ohm resister in series.
    The old controller had an output to wire #217, which I am thinking was +24VDC.
    Attachment 392134 LINK
    So, I am thinking for the Spindle to run through Kanalog/KFLOP I need wire #217 connected to JP13 Opto Output (I will be use # +7) which will:
    1.) Wire #217 must be connected to Kanalog JP13 Opto Output (# +7) so when KFLOP reads a "M03" and "S" NC Code -- this JP13 Opto Output (# +7) would provide +24VDC to wire #217 (which is connected to 13CRE relay).
    2.) So when wire #217 on 13CRE relay gets +24VDC then wire #218 on 13CRE relay would have +24VDC -- which in turn would feed wire #218 connected to 12CRE relay which would turn 12CRE relay on.
    3.) Once 12CRE relay is on then wire #243 would connect to wire #242 which is also connected to 12CRE relay and the other end of wire #242 is connect to DI2 on the VFD terminal.
    4.) And the wire #242 get +24VDC from the VFD +24VDC terminal because ....
    5.) Wire #243 and wire #241 are connected together just outside of the VFD (separate from the VFD bus terminal).
    6.) However, since 1CR relay is on at this point, wire #240 (which is connected to the VFD +24VDC terminal), now has +24VDC from the VFD +24VDC terminal which in turn feeds wire #241 on 1CR relay (when on) with +24VDC.
    7.) So, I am thinking this is how wire #242 on 12CR relay gets the +24VDC from the +24VDC VFD terminal, which is connected to DI2 terminal on the VFD.
    This LINK has the 1CR, 2CRE, 12CR, and 13CRE relays wire pin for quick reference (see last 4 images of link).
    Do all KMotion Bits work the same as far as setting them on and off?
    So, I should be able to turn the "FET Driver 0" Bit (in my case #152)
    on by: SetBit(152); // FET Driver 0 on (Relay), Spindle will go on thru Interlock
    and
    off by: ClearBit(152); // FET Driver 0 off (Relay), Spindle will go off thru Interlock
    Tree325 Retrofit Started-kmotion_digital_i_o_screen_4k_large-png
    J325 Quick Links:
    Machine
  5. #233
    Aug 2008
  6. #234
    May 2006
    Hi PeterTheWolf,
    I'm a bit confused. You will need to turn FET Driver 0 on and off instead of OPTO Out 7. OPTO Out 7 should no longer be needed. It isn't clear to me if we will then have the proper interlocks enforced by some of the original wiring (EStop. Drawbar, and such). You should test that.
    Yes all output bit can be controlled by SetBit and ClearBit in the same manner. Just use the associated bit number.
    Regards
  7. #235
    Aug 2008
    Regards
    Thanks Again Tom for paying close attention to my moves on this retrofit!!!
    You absolutely correct
    ... The OPTO Out #7 wires are no longer used. I made the mistake of disconnecting the two wires from the VFD and not disconnecting them from the Kanalog (instead I left them in place as I tested the option #3 of the relay.)
    And in my post to the forum I wasn't paying close enough attention to what exactly I had ended up with on my wiring.
    I really appreciate your depth of insight into the posts on this forum. For beginners (like me) using KFLOP/Kanalog ... it makes a World of difference, at least in my understanding.
  8. #236
    Aug 2008
    Can I please get some clarification on using the KMotion C-Program editor and how it works?
    If I am running KMotionCNC and I have C-Programs defined in the Tool-Setup parameters ... like:
    Tree325 Retrofit Started-tool_setup_page_001-jpg Link to Image
    Where the M3, M4, M5, and S are defined via C-Code files and I open the KMotion C-Program editor and edit one of these files lets say in Thread #4, re-compile, Download, and Run ... which C-Code is KMotionCNC responding too?
    Another Question:
    If I am in KMotion C-program editor and I open threads #3, 4, 5, and 6 with M3.C, M4.C, M5.C, and Spindle.C respectively ... will the variables defined and used in, lets say M3.C be available to Spindle.C?
    If not, how can I use variables defined and set in one C-program in another C-program?
    Another Question:
    If I want to use a longer USB cable (9 feet) to connect KFLOP to Laptop, does it have to have the ferrite chokes on each end of the USB cable like the one that came with KFLOP/KMotion?
    Tree325 Retrofit Started-ferrite_choke_usb_cable-jpg Link to Drawing
    J325 Quick Links:
    Machine
  9. #237
    May 2006
    Hi PeterTheWolf,
    When KMotionCNC decides it needs to perform some action (such as M3) it looks in the Tool Setup for what it is supposed to do. In this case it Compiles and downloads to KFLOP the C file it was configured to use into the KFLOP Thread that it was configured to use. Then executes that Thread. This is all regardless of what programs were last used in whatever Threads in KMotion.exe. KMotion.exe is simply a configuration and debugging tool to help with experimentation and testing. In the end it will not be needed or used at all. However if you use KMotion.exe or any other editor to modify the disk file that KMotionCNC is configured to use, then of course the next time KMotionCNC uses the file it will use the modified file.
    In general no.
    The simplest method is to place data into persist user data variables. There are 200 variables defined 0-199. Each is a 32-bit integer which can hold any whole number between (-2147483648 to +2147483647). Floating point values can also be placed into these variables although it requires some special casting to force the compiler to reference the variable as a float rather than an integer. Not only will the data be available to other C Programs and Threads, it will be available to the same C Program if executed at a later time. Think of it as a chalkboard where anybody can erase and write a value which anyone else can read or you can read yourself at a later time. Of course if anyone writes a new value any previously written value will be lost. To access a variable from C code: persist.UserData[xxx] where xxx is the variable number you wish to reference. The persist.UserData can also be Flashed to KFLOP memory so the value Flashed will persist after the next power cycle. But this is not normally necessary or recommended.
    Its not absolutely necessary but highly recommended. The ferrite rings have been shown to help reduce noise problems. Something else to check is that the shield resistance from shell to shell is < 1 Ohm. Many low cost cables do not meet this requirement even though they claim to be compliant so its worth checking.
    HTH
    Regards
  10. #238
    Aug 2008
    Thanks Tom ........ I will do some more testing and experimenting.
    Question:
    Tom, Do you offer a 10 foot USB cables for sale from Dynomotion Motion Control Boards? I do not see them on your web site. If so, How can I order them?
    Thanks,
    J325 Quick Links:
    Machine
  11. #239
    May 2006
    Hi PeterTheWolf,
    No we don't. There are many sources. This is a brand we've had good luck with on Digikey:
    https://www.digikey.com/product-deta...414-ND/3782937
    Regards
  12. #240
    Aug 2008
    Can I get some help with my, what should be simply, C-Code?
    I am trying to write some C-code to change the << DAC(7,speed); >> value "speed" from Positive to Negative and/or Negative to Positive for the M03/M04.
    At least what I thought should be simple is not working so well. It would seem the I cannot get the correct sign on the this "speed" value when it is needed base on the M03 and/or the M04.
    What I thought should happen is the M03/M04 code would be read first in the "Tool Setup Screen" and then the "S" code from the Spindle.C which I though should setting the "speed" value sign correctly.
    But this is not the case.
    The NC code I am testing is:
    M05
    M03S200
    M05
    M04S200
    M05
    M30
    My Spindle.C is this:
    Code:
    #include "KMotionDef.h"
    #define FACTOR 0.2228  // Factor 0.2228 * Speed from NC code for DAC7
    #define SPEEDVAR 99			// global persistant variable to store latest speed
    #define STATEVAR 98			// global persistant variable to store latest state (-1=CCW,0=off,1=CW)
    main()
    	int speed;
    	float spd = *(float *)&persist.UserData[9]; // s value from g code
    	speed = spd * FACTOR; // set dac counts
    		printf("Spindle Speed = ");  //single line comment
    		printf("%4.4f\n",spd);
    		printf("Factor Used Spindle Speed = ");  //single line comment
    		printf("%4.4f\n",FACTOR);
    	// limit min speed
    	if (speed < 60)
    		speed = 60;
    	// limit max speed
    	if (speed > 1000)
    		speed = 1000;
    	if (persist.UserData[STATEVAR] == -1)  // should be M04
    		DAC(7,-speed);
    		persist.UserData[SPEEDVAR] = spd;
    		printf("%d\n",persist.UserData[SPEEDVAR]);
    		printf("Print the value for STATEVAR for M4 in Spindle.C = ");  //single line comment
    		printf("%d\n",persist.UserData[STATEVAR]);
    		printf("\n");
    		printf("\n");
    		printf("\n");
    	if (persist.UserData[STATEVAR] == 1) // should be M03
    		DAC(7,speed);
    		printf("Print the value for STATEVAR for M3 in Spindle.C = ");  //single line comment
    My m3.c code is this:
    Code:
    // M03 C-Code for Spindle Direction
    // Spindle CW Jog function with +/- voltage used for direction
    // M03 command passes no arguments
    // desired speed is read from user variable SPEEDVAR
    // save in user variable STATEVAR whether it was off, CW, or CCW (0,1,-1)
    // save in user variable SPEEDVAR the last desired speed
    main()
    	persist.UserData[STATEVAR] = 1;
    			// SetBit(151); // spindle on; when OPTO Out #7 is used to signal spindle direction
    		printf("Print the value for STATEVAR from M3.C = ");  //single line comment
    		printf("\n");
    		printf("\n");
    		printf("\n");
    My m4.c is this:
    Code:
    main()
    	persist.UserData[STATEVAR] = -1;
    		printf("Print the value for STATEVAR from M4.C = ");  //single line comment
    		printf("\n");
    		printf("\n");
    		printf("\n");
    Also, I was trying to use other C programming syntax I see on online however, it would seem I do not have the correct default C Standard Input and Output Library like "stdio.h" and "stdlib.h".
    However, if I try to add these at the beginning of the Spindle.C program as #include "stdio.h" the compiler does not like it and/or there are other libraries within the library that also are not available.
    Is there a way to get more of these default C Standard Input and Output Library included in the C-code I am trying to write for KMotion?
    J325 Quick Links:
    Machine
