Build Thread Taig CNC-Controller Replacement-Dynomotion Suggestion - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
Thread: Taig CNC-Controller Replacement-Dynomotion Suggestion
  1. #41
    Member PeterTheWolf's Avatar
    Aug 2008
    Default Re: Taig CNC-Controller Replacement-Dynomotion Suggestion
    Quote Originally Posted by TomKerekes View Post
    If you were to choose IO 34 or 35 (pins 15 or 16) there aren't any pull down resistors so the full 16ma would be available. Under a load of 5ma (instead of 16ma) the output would likely be higher than 2.4V but still there is no guarantee it would be 3V or higher. Most likely it would be. You could verify with a voltmeter if it actually is 3V or higher.
    This works. I am getting 1.5mV on KFLOP JP6 Pin 16 (IO35) with this relay connect and 3.27VDC on KFLOP JP6 Pin 16 (IO35) when I turn it on in Kmotion Digital I/O screen and the relay is pulled in.
    Thanks Tom ...........
    Taig CNC-Controller Replacement-Dynomotion Suggestion-5v_relay_kflop_wiring-jpg Link to Word Doc.
    Taig CNC Machine Quick Links
    KFLOP Power Suppy
    Stepper Motor Power Supply Used
    Stepper Motor Used on Taig
    Taig CNC Machine Counter Weight Design
    Taig CNC Machine Counter Weight Design - 3D STEP File
    Word Doc. of my Calculation for the Trajectory Planner
    Word Doc. E6 Optical Kit Encoder
    Relay Connection to KFLOP JP6 Pin 16 (I/O 35)
  2. #42
    Member TomKerekes's Avatar
    May 2006
    Great. Thanks for taking the time to post back.
    Regards
    TK http://dynomotion.com
  3. #43
    Aug 2008
    Hi Peter,
    Higher resolution is always better until you exceed the count rate of the encoder input at maximum RPM. KFLOP can conservatively accept 1 million quadrature counts/second.
    2000 cycles/rev at 2000RPM would be:
    2000 x 4 x 2000 / 60 = 266K counts/sec
    And at 20 TPI would give a resolution of
    20 x 2000 x 4 = 160,000 counts/inch (6.25ui)
    I will not be able to use Linear Glass Scale on the Taig ... just not enough room for mounting it on the X-Axis.
    So, I will be going with the US Digital E6 rotatory encoder.
    Tom,
    If more is better and I will max. out at 1000 RPM with these stepper motors,
    shouldn't I use an encoder with 4000 CPR?
    Another question I have is, should I be configuring these encoders with the "Index" or "No Index"?
    Thanks,
    KFLOP Power Suppy
  4. #44
    May 2006
    Hi Peter,
    4000 cycles/rev would be:
    4000 x 4 x 1000 / 60 = 267K counts/sec
    and should work fine.
    An Index pulse can help with more accurate homing. You would first search for a home/limit switch and then search for up to one revolution for the index pulse. Its up to you. If you include the Index pulse output you can always just not connect it and not use it.
    Regards
  5. #45
    Aug 2008
    Tom,
    I am using the E6 Rotary Encoder on the back of one Stepper motor for testing.
    I have put together of HTML link for a Cable Pinout from the Encoder to KFLOP via RJ45 and a C46 Differential to Single Ended Converter (from Welcome to CNC4PC).
    Can you please double check my pinout?
    My main concern is the last image of the HTML Link to ensure I am understanding the connection to KFLOP.
    This is only for one axis; however, the last RJ45 connection to KFLOP will be with all three axis.
    Taig CNC-Controller Replacement-Dynomotion Suggestion-004_rj45_breakoutboard_to_rj45_end_for_kflop-jpg
    KFLOP Power Suppy
    E6 Encoder PinOut to KFLOP PinOut
  6. #46
    May 2006
    Hi Peter,
    That seems correct to me.
    But it isn't clear that GND and +5V from KFLOP are being supplied to all the encoders (C46) pins 1 and 2.
    Regards
  7. #47
    Aug 2008
    Yes .... I should have depicted this as well , I was thinking I would connect to the RJ45 break-out board Pin #2 & Pin #1 with the use of KFLOP JP6-Pin #1 for +5VDC and KFLOP JP6-Pin #8 for Ground, respectively.
    Do you see any issues with this?
    Thanks,
    KFLOP Power Suppy
  8. #48
    May 2006
    That should work.
    Regards
  9. #49
    Aug 2008
    I finally got everything connected in a working PC case (Enclosure) . I am now ready to start testing the X-Axis with the rotary axis encoder connected to the back-side of the stepper motor.
    However, I am not sure on what I should be using on "I" Gain for the initial PID ("I" Gain ) setting for testing in the "Step Response" screen on my testing.
    I have a few question:
    REF.: 4000 * 4 * (1000/60) = 267K Counts/Sec.
    1.) When dealing with rotary and/or linear encoders, is the Cycles/Rev. the Same as the Step/Rev?.
    2.) Is my math correct? If I have a rotary Encoder that has a 4000 cycles/Rev. = 4000 Cycles/Rev. * 20 Rev. /IN = 80,000 Cycles / IN?
    3.) If this is correct, then (80,000 Cycles/IN) / (64,000 Steps/ IN) = 1.25, which will = the Input "I" Gain on KFLOP "Step Response" screen. I should be using this "I" Gain for testing my X-Axis with a Rotary Axis on the stepper motor on the initial tuning.
    KFLOP Power Suppy
  10. #50
    May 2006
    Hi Peter,
    Start with a small number such as 0.0001 to observe gradual corrections.
    I don't understand what you are asking. Rotary encoders have quadrature counts per rev. Linear encoders have quadrature counts per inch.
    I believe that is correct. But we are normally interested in quadrature counts not cycles. So that would be X 4 or 320,000 counts/inch.
    Assuming 320,000 encoder counts/inch and 64,000 steps/inch then the InputGain should be 64000/320000 = 0.2 to have them count at the same rate.
    Note I believe you are confusing Integrator gain ('I' gain) on the Step response screen with InputGain on the Configuration Screen. They are different things. The first just scales the encoder reading. The latter controls how fast errors are attempted to be corrected. You might read this.
    HTH
    Regards
