NEED HELP getting KFLOP & MACH3 setup to run a Grizzly G0704 Converted to CNC
Results 1 to 2 of 2
Thread: NEED HELP getting KFLOP & MACH3 setup to run a Grizzly G0704 Converted to CNC
    Oct 2016
    Default NEED HELP getting KFLOP & MACH3 setup to run a Grizzly G0704 Converted to CNC
    Hello,
    I recently purchased a Grizzly G0704 that was converted to CNC based on Hoss's plans.
    Kflop control board with Gecko drives running Nema 23's on all axis.
    I would like to run Mach 3 (using the new Kflop plug in
    I have been trying to get it to run, however at this time it doesn't appear that I am bright enough to get it set up on my own.
    Would love some guidance, especially if you have the same/similar setup.
    Jeff
    Oct 2016
    Default Re: NEED HELP getting KFLOP & MACH3 setup to run a Grizzly G0704 Converted to CNC
    PM sent- Thanks!
    Quote Originally Posted by majami View Post
    Hi Jeff
    I can help you to startup your machine with kflop and mach3.
    Where are you located ? I am in Los Angeles.
    What is your email ?
    Matt
