Need Help! K2cnc spindle stopped for KG-4925 - Page 5
Page 5 of 8 FirstFirst ... 2345678 LastLast
Results 81 to 100 of 158
Thread: K2cnc spindle stopped for KG-4925
  1. #81
    Jun 2005
    Default Re: K2cnc spindle stopped for KG-4925
    Robert,
    Be VERY CAREFUL when measuring these voltages. The UVW signals are the power to the motor they are reading low because the motor is not spinning.
    I am checking the VFD manual right now to see if I missed one of the parameters. Agree it is very close.
    This VFD needs to have 220VAC between L1 and L2 are you sure you have it wired up to 220V single phase. I see they have wires on all three phases but you need to unplug the VFD and take a picture of the plug and ensure you actually have 220V power, it will never spin on 120V.
    Russ
  2. #82
    Jul 2015
    Russ,
    I'm pretty sure it's wired for 3ph. We have 208 vac btw legs 1/2 and 1/3. I get 120 if I test btw ground and any leg.
    Robert
    Attached Thumbnails Attached Thumbnails K2cnc spindle stopped for KG-4925-img_1594-jpg
  3. #83
    Jun 2005
    Robert,
    Please check the following parameter.
    04-07 this is for the multifunction input #4 which is wired on the VFD and I also saw another K2CNC machine that uses that same input.
    04-15 is AUI analog input bias, what is this set at right now?
    04-16 is AUI bias polarity, what is this set at right now?
    04-17 is AUI input gain, what is this set at right now?
    04-18, is No AUI negative bias command, what is this set at right now?
    Also check
    05-00 to 05-14, these are step speed frequencies.
    finally check 05-15 and let me know how it is set as well. Thanks
    Russ
  4. #84
    Jun 2005
    Robert,
    OK, please check between phases, L1 to L2, L2 to L3, L1 to L3 if you have three phase power. If all of those measure about 220V that is good and we can move to the next step. Each of the phases should measure 120VAC to Ground.
    Russ
  5. #85
    Jul 2015
    Russ,
    Here is what I have.
    04-07 set to 20
    04-15 set to 00
    04-16 set to 00
    04-17 set to 100
    04-18 set to 00
    05-00 to 05-15 all set to 00.
    Robert
  6. #86
    Jul 2015
    Quote Originally Posted by CNCMAN172 View Post
    Robert,
    Russ
    OK we have 208 power to the shop so all reading are 208 btw legs L1 to L2, L2 to L3, L1 to L3
    Robert
  7. #87
    Jun 2005
    Robert,
    That is perfect. Now will you take a few minutes and fill out the YELLOW part of this excel worksheet with your VFD settings and we can get this last issue fixed.
    Russ
    Attached Files Attached Files
  8. #88
    Jun 2005
    Robert,
    I appears they are using MI4 as an EMERGENCY STOP input to the VFD so if Kmotion has estop condition it will stop the spindle.
    Back in about an hour have a work call.
    Russ
  9. #89
    Jul 2015
    Russ,
    I did not have excell on the cnc computer so I had to transfer from another computer.
    here it is!
    Robert
  10. #90
    Jun 2005
    Perfect,
    Now can you please send the details of your spindle, the model perhaps a photo that shows the label with the various parameters like Speed, etc. I need to ensure those are correct in your VFD.
    Russ
  11. #91
    Jul 2015
    Hi Russ,
    Sorry I stepped away.
    See attached for HSD spindle info.
    Robert
    Attached Thumbnails Attached Thumbnails K2cnc spindle stopped for KG-4925-hsd-spindle-plate-jpg   K2cnc spindle stopped for KG-4925-hsd-spindle-jpg
  12. #92
    Jun 2005
    OK perfect, in a meeting right now will get you some adjustments in about one hour.
    Russ
  13. #93
    Jun 2005
    Robert,
    OK, I know what is wrong, but not exactly why. Let me explain....
    First make the following changes in the VFD
    02-05, set to 00
    02-11, set to 03
    02-13, set to 03
    02-15, set to 300
    04-07, set this one to 00, this is only a TEMP setting while I provide a point. This is used for the ESTOP input into the VFD from MI4.
    The problem is the spindle is not starting because it being faulted immediately by the ESTOP input. We are going to disable temporarily to get the spindle to work.
    This is probably and issue because a program is messed up in a c program, which I will investigate or a hardware fault on the breakout board. After you make these changes please see if the Spindle moves when commanded.
    Russ
  14. #94
    Jul 2015
    Russ,
    No luck with the new settings.
    Robert
  15. #95
    Jun 2005
    Robert,
    Did anything happen did you see anything flashing on the VFD, anything at all? We might set the VFD to manually control the spindle from the VFD keypad to ensure the spindle is actually good and working.
    Russ
  16. #96
    Jun 2005
    Robert,
    I forgot to mention because the VFD faulted please turn it off and turn it back on to ensure it has the fault cleared and test it again.
    Russ
  17. #97
    Jul 2015
    Russ,
    Yes, stuff happens but I'm not sure what I should be paying attention to.
    Example, in the 'H" display it starts at 0.00 and when spindle is activated this number goes up to about 4000 give or take a couple of hundred because its in flux and then back down to 0 when spindle is off.
    "U" stays at 4000 with flux.
    "HU" starts at 0.00 and goes to about 2000 and then back to 0 when spindle is off.
    "F" starts at about 8 then goes to about 70 but only after a turn everything on. It does not seem to react to the spindle on/off.
    Robert
  18. #98
    Jun 2005
    Robert,
    "F" is the requested Frequency, so F at 8 is extremely show pretty much off. When F goes to 70 that is requesting 70Hz out of max of 300Hz so about 25% of the spindle speed.
    "H" is the Output Frequency at the motor terminals, that should be between 0 and 300Hz again, so not sure the 2000 makes sense.
    You can program the screen to output different information, I might have you set the VFD for keyboard control and see if you can get the motor to spin at all.
    Have you ever seen this motor run at all?
    Russ
  19. #99
    Jul 2015
    Yes, it was running shortly before everything started to go haywire.
  20. #100
    Jun 2005
    Robert,
    We need to do a test with the VFD and Spindle to ensure they still work. You might have lost the spindle or VFD or both, the VFD does seem to be doing something so maybe it is fine. First turn off the VFD and when the display is blank try and rotate the spindle with no power, please ensure it spins easy in both directions. Also smell and see if you detect any burnt smell around the spindle.
    If both of those look good, then I will have you program the VFD to control the spindle using just the VFD keypad.
    Russ
