IO SIGN
Results 1 to 3 of 3
Thread: IO SIGN
    Feb 2011
    SPAIN
    Default IO SIGN
    Hi anyone, today I´ve got two questions I would like to know how read with the instruction (readbit) a bit 0 lever that's to say how to detect that the bit has changed from 1 to 0.
    tha second question is reated to software, and C programming, there are many programs that Tom has made as examples, some of them include Loops that are executed for ever. my question how can include two o more than two of these loops in the same program, what's the correct way If so can you post an example.
    thanks in advanced
    Carlos
    Member TomKerekes's Avatar
    May 2006
    Hi Carlos,
    To do something when an input transitions from 1->0 you might write some code to remember the last state and look for the case where the new state is now 0 but the last state was 1. Here is an example:
    int NewState,LastState;
    LastState=ReadBit(46);
    for ( ; ; ) // loop forever
    NewState=ReadBit(46);
    If (NewState==0 && LastState==1)
    // do something because bit changed from 1 to 0
    LastState=NewState; // remember the last State
    For the case where there multiple things that you wish to be continuously monitored you can use a single loop and put all the things you need to do in the same loop. See below:
    // Do one thing here
    // Do something else here
    HTH
    Regards
    TK http://dynomotion.com
    Feb 2011
    SPAIN
    Thanks very much, Tom
IO SIGN
IO SIGN
