Pressing Reset in Mach3 set Machine coords to 0?
Results 1 to 5 of 5
Thread: Pressing Reset in Mach3 set Machine coords to 0?
    Oct 2010
    Exclamation Pressing Reset in Mach3 set Machine coords to 0?
    Why does pressing Reset in Mach3 set Machine coords to 0?
    I've attached my init the gets executed when I press Reset in Mach3.
    Thanks,
    Dennis
    Attached Files Attached Files
    Member TomKerekes's Avatar
    May 2006
    Hi Dennis,
    In your Init program when you enable your axes you are setting the destination to be the encoder position which is probably zero. Instead set it to the current Destination such as:
    EnableAxisDest(0,ch0->Dest);
    Regards
    Regards
    TK http://dynomotion.com
    Oct 2010
    Just had a thought...I'm using steppers in an open loop configuration. Is wind-up or position error really even an issue since the controller really has no idea where my machine is?
    I can see needing this down the road when I add encoders and go to a closed loop system.
    Thanks,
    Dennis
    May 2006
    Hi Dennis,
    Not sure exactly what you mean. But correct, without feedback or a servo following error or Integrator Wind-Up simply don't apply.
    Regards
    Regards
    Oct 2010
    Thanks Tom,
    The EnableAxisDest(0,ch0->Dest); works perfectly.
    -Dennis
