The Dyna Myte 3000 Project - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 81 to 87 of 87
Thread: The Dyna Myte 3000 Project
  1. #81
    Mar 2007
    Romeo, Michigan, USA
    Default Re: The Dyna Myte 3000 Project
    Fastest1 - Could you post your .DXF files of the motor mounts for the rest of us ?
    [url]www.CNC-Joe.com[/url]
    CNC Is Not Just My Passion.. It's My Addiction !!!!
  2. #82
    Member Fastest1's Avatar
    Nov 2009
    Hope this works for you. Btw, I use BobCad. That file looks terrible in my autoviewer or whatever opens the dxf.
    Attached Files Attached Files
    A lazy man does it twice.
  3. #83
    Mar 2007
    Thank You! I just saw that you had placed that out there. Sorry for that!
  4. #84
    Sep 2012
    Where did you get the pulley you used for the X axis to replace the plastic gear?
    Having a hell of a time finding anything that looks like that besides "gear stock"
    Thanks,
    Andrew
  5. #85
    Nov 2009
    I did make it from gear stock. They come in all sizes and tooth profiles. SDPI.
    I just got a set of direct drive mounts for Dyna's. It was from a member here that had an impressive build many years ago. Here is what I got. A link to his build.http://www.grifftek.com/images/dyna2400remec/
  6. #86
    Sep 2012
    Quote Originally Posted by Fastest1 View Post
    That's not for the DM 3000 is it? If so would you mind sharing the cost?
    Sent from my Nexus 6 using Tapatalk
  7. #87
    Nov 2009
    Most likely they will work on all this class of dyna's, 2200, 2400, 2800 & the 3000. He was cleaning out his storage and sold me all of it. 5 mounts, 3 sets of couplers a few steppers. The only limitation I can see is maybe due to the thickness of the mount it will lose some travel due to the enclosure of the lathe. It would be a minimal loss on the lathe and most likely not taking any cuts at max diameter. Unfortunately I think my enclosure I built for the mill years ago might have the same issue. I have no intention of losing any travel on the mill.
