The Dyna Myte 3000 Project - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 87
Thread: The Dyna Myte 3000 Project
  1. #61
    Member Fastest1's Avatar
    Nov 2009
    I did get a confirmation email that the connectors were mailed.
    A lazy man does it twice.
  2. #62
    Nov 2009
    JST sent me 33 connectors. Woo Hoo.
  3. #63
    Nov 2009
    A small update as I wait for my SMD fuses to repair my MX3660. Just a reminder don't pull the power plug at the unit immediately after turning off the power supply. Let it bleed down for a moment or two. No problems there, that was an easy diagnosis.
    I did come up with a way of installing a pulley in place of the old plastic gear, reusing the original hub. I plan on installing the stepper under the bed, out of the way.
    Here are a few pics.
    The Dyna Myte 3000 Project-imageuploadedbytapatalk1386368622-201133-jpg This is the original hub.
    The Dyna Myte 3000 Project-imageuploadedbytapatalk1386368663-766932-jpg I recessed the pulley just enough to keep it centered.
    The Dyna Myte 3000 Project-imageuploadedbytapatalk1386368729-883686-jpg Checked for fit prior to drilling.
    The Dyna Myte 3000 Project-imageuploadedbytapatalk1386368774-400432-jpg It fits.
    The Dyna Myte 3000 Project-imageuploadedbytapatalk1386368817-633844-jpg This it it installed. Now on to the stepper mounts.
    If anyone is interested the hub is 1.57" in diameter, .1665" thick at the mounting flange and the center hole is .79" Fits like a glove.
  4. #64
    Nov 2009
    I have been thinking about electronics and organization. Here is a teaser. It is slowly coming along.The Dyna Myte 3000 Project-imageuploadedbytapatalk1393296577-707771-jpg
  5. #65
    Registered MRM RCModels's Avatar
    Jul 2007
    Looks strangely familiar. ....lol
  6. #66
    Nov 2009
    Default Re: The Dyna Myte 3000 Project
    Stepper mount testing. Looks good. Going to shorten it a little bit. Btw the motor could fit on the front instead of under the bed. Direct drive is not a possibility on the X due to clearance issues of the carriage itself.The Dyna Myte 3000 Project-imageuploadedbytapatalk1396186084-395164-jpgThe Dyna Myte 3000 Project-imageuploadedbytapatalk1396186114-709580-jpg
    Also you might notice a little groove between the 2 mounting holes on the left side. If you are going to use a different "top of part" in a pocket, remember your clearances must be higher. Sometimes I am glad I cut a proof in MDF. Plus I am waiting for some end mills.
  7. #67
    Mar 2007
    Romeo, Michigan, USA
    Nice Build Log, Fastest1. I just picked up my 3000 over the weekend. Going to try to get it running as it came from the factory at first. But definitely want to upgrade to Gecko's, etc in the near future.
    Please keep posting pics and info.
    Joe
    [url]www.CNC-Joe.com[/url]
    CNC Is Not Just My Passion.. It's My Addiction !!!!
  8. #68
    Mar 2007
    Fastest1,
    - Which controller did you end up with for the Spindle motor?
    - Was it difficult to interface this to your Break Out Board and Mach3 ?
    Thanks for your info on your build.
    Joe
  9. #69
    Nov 2009
    Bardac 1600i
  10. #70
    Jul 2007
    Quote Originally Posted by Fastest1 View Post
    Bardac 1600i
    Yep. Same one
  11. #71
    Mar 2007
    Thanks MRM & Fastest1
    Good to see that you're still around MRM!
    - I want to duplicate your build... maybe take it up a half a notch...
    - MRM please PM me with a good email address (same for you Fastest1).
    Thanks!
    Joe
  12. #72
    Nov 2009
    Default The Dyna Myte 3000 Project
    What? I havent given up? Some of us are just slower than others!
    The Dyna Myte 3000 Project-imageuploadedbytapatalk1413509056-929464-jpg
  13. #73
    Nov 2009
    I was just checking for fit at this time. Unfortunately right as I was cutting the part free on a roughing pass, it slipped. I thought I had the part clamped tightly separate from the vise. I did catch it in time. Tomorrow I will fix it to the table and pick up a datum point in 1 of the holes and do the finish pass, likely have to adjust it a thou or 2 now. 2 days in the vise only to have a crash at the end. Typical.
    I learned quite a bit making this part. It came out of the vise once. Lost tram in 1 crash. Fixed it all, realigned it and recovered.
    The interior of that part has had no clean up of any kind. See if it the exterior looks that good tomorrow!
  14. #74
    Jul 2007
    Oh I remember that fun. Looks good though
  15. #75
    Nov 2009
    Here it is finished and fitted. Will redo the cover as that was some scrap I made on my wooden proof. Likely omit the slot and route the wiring out the right side.
    The Dyna Myte 3000 Project-imageuploadedbytapatalk1413582149-093804-jpgThe Dyna Myte 3000 Project-imageuploadedbytapatalk1413582164-810298-jpgThe Dyna Myte 3000 Project-imageuploadedbytapatalk1413582179-876658-jpg
  16. #76
    Dec 2004
    Looking good.
  17. #77
    Member Big Chips's Avatar
    Jun 2012
    what are you doing for tooling. I just picked up my Dm 3000 last night from a me,ber here and it is fully optioned out and came with tools...but the only with one drill bit adapter and a few sleeve/reducers. Is this somethign that can be purchased or do i have to make it?
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
  18. #78
    Jul 2007
    Quote Originally Posted by Big Chips View Post
    Welcome to the club big chips. Call Robert at dyna mechatronics. The keep quite a few things in stock. Warning: it ain't cheap
  19. #79
    Jun 2012
    like your videos on youtube...wish you would put up a vid showing how to touch off the tools... thanks for the reply
  20. #80
    Jul 2007
    I will be using the 3000 on my next kickstarter. Will do
