With or with out tailstock ? What type of chuck , center, collet chuck are you going to use ?
Can anyone confirms me DM3000 Z travel disltance, is it 11inch?
THX,
- Z axis travel distance?
- Need Help!- Question on Travel Distance
- Need Help!- Mach 3 travel distance
- Newbie- distance z axis can travel
- Travel distance is inaccurate.
Hi Gabedrummin,
Below is my DM3000, it would be great to know both the distances with Tailstock and without.
Can those information be found in the Dynamyte 3000 Manual 1 and 2 or Service manual?
It will travel to the right until the carriage hit's the limit on the back side of the bed . It will travel z- till it crashes into the chuck if you don't stop it . So the limit switch on the back is adjustable so you can adjust the home position .The length of z travel is between those two points.
MY machine has about 8 inches of z with the tail stock on and about 12 with it off .
