You don't need to tighten them to like 80 foot pounds or use red locktite (like some holders I bought). a dozen should do you. Money well spent.
Recommended torque on the pull studs is 25 to 35 ft/lbs. I use the lower number.
I also put anti seize on the threads and face. Makes it real easy for switching them out later.
I haven't counted lately but my tool cabinet has over 250 tool holders in it.
At least 50 are dedicated to drill and another 50 to end mills.
If my program calls for any common drill, I just grab it off the shelf, enter the offset and away it goes.
I can switch up tooling and programs in less than ten minutes.
Timothy
Dyna Mechtronics DM4400, HAAS VF-0E, HAAS Mini Mill
Good afternoon my friends, My name is fabio seabra alive in portugal, owner of a motorcycle shop and workshop, Mxcross.pt Portugal,
I recently bought this machine DYNA MYTE 2800 for my workshop, would you like someone to help me get it working on cnc connected to pc, or if the easiest thing would be to convert to mach3 program?
I would very much like you to help me please my friends,
In Portugal there is very little knowledge
