Dyna Myte 2400 and Mach3
Results 1 to 2 of 2
Thread: Dyna Myte 2400 and Mach3
    Member tom213's Avatar
    May 2020
    Default Dyna Myte 2400 and Mach3
    Hi folks,
    I have bought a Dyna Myte 2400 and now I want to connect it to mach3. Unfortunately, I have no idea how to configure mach3 to get it working with the dyna myte.
    I have connected my PC via plain 25pin parallel port to the milling machine. Is this correct? How do I need to configure the I/O in mach3 to get the machine working.
    I have also read about refitting the Dyna Myte to work with mach3. Is this absolutely required? Or should it work with stock electronics also?
    Regards,
    Tom
    Mar 2005
    Default Re: Dyna Myte 2400 and Mach3
    I have no direct experience with the DM 2400, but the control is quite similar to the DM 3000H lathe that I have. That 25 pin connector that you're connecting to is most likely an RS-232 serial port for sending programs to the SKIP controller.
    Sorry, you won't be able to just connect a PC with Mach3 and go like you're trying.
    Dave
