- DM2400 Oil/Grease
DM2400 Oil/Grease
I was hoping for some clarification. I have only seen the oil chart and table from bad scans.
My mill has the manually operated piston type oiler, and calls for Shell 32T. Why are there so many oils listed on the chart? Am I supposed to be oiling other locations on the mill than what is fed by the automatic oiler?
Also, can anyone recommend a grease for the stepper gears and thrust bearings? Is NLGI 2 the right viscosity?
Re: DM2400 Oil/Grease
What are you using for way oil? I am assuming most users are using a #2 way oil rather than a #1. Is this correct?
- DM2400 Oil/Grease
- You may not post replies
- You may not edit your posts
Forum Rules
