- DM 2400 8 Wire Stepper Motors
I am curious if anyone has any information on the PMI SynchroStep model# 00S52R6008 8 wire stepper motors that came on the dm2400. I have tried to search for information and have come up empty handed, except for the fact that they were a KollMorgen product.
I am looking for information as I want to turn the steppers into 4 wire steppers, but I am not sure which of the coils should be paired up.
Fastest1 had posted that his were Portescap P532 258 0.7 14's. I believe they may be the same motor rebranded as they were also a disc style stepper.
I have thought about removing the motors, but if I keep the original mounts then I would have to cut shafts down.
Does anyone have any additional information on this motor or the pinout?
Re: DM 2400 8 Wire Stepper Motors
Does this look like the same motor?
https://photos.app.goo.gl/H4Dc8CT3XQcj7ETF6
It's from my DM4400, it's a Kollmorgen Synchro Step but no model # on it. 200 steps, 140 oz. in.
I have mine set up as 4 wire (parallel) so if it's the same I can scan that info in for you. I also have a cheat sheet for figuring out what wires are what.
Dan
Edit: I meant to say 8 wire parallel, I was assuming that's what you meant, so 4 pairs of 2 wires each.
- You may not post replies
- You may not edit your posts
Forum Rules
