Well looks like these do not fit. Close but not good enough. Anyone know the correct size?
Received replacement belts today.
Item #T5-325
13mm wide
Bought them from Chris Connor
Inside Sales
Megadyne - Belt Corporation
253 Castleberry Industrial Drive
Cumming, GA 30040
Phone: +1 (770) 887-9725
Fax: +1 (770) 887-4138
They were about $8 each. Very easy to deal with. Sent them an old one and they matched it.
Cheers
Don
Whoops wrong size. Should have cut one first.
So I did cut one and laid it out flat and measured. It is 330.2 mm long (13") with 65 teeth. This makes it a XL belt with a pitch of 5.08mm or 0.2".
Stock Drive Products has them too.
They are 9.5mm wide but they work well.
Timing Belts - XL Profile - Inch Sizes
Timothy
Dyna Mechtronics DM4400, HAAS VF-0E, HAAS Mini Mill
